Garden Logo
ConnieandChris Humphries Posted on Dec 25, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
RYOBI 31cc 150mph 310BVr I need to know how to install new lines from tank to bubble to carb correctley
Jim Parker
Level 3:
  • Master 1,041 Answers
  • Posted on May 29, 2016
Jim Parker
Master
Level 3:
Answers
1041
Questions
5
Helped
536319
Points
2636
Hi Connie & Chris,
Here is a link to your problem:
https://www.youtube.com/watch?v=D3lmi3rtmh0
Good Luck!
Jim
4 Related Answers
Anonymous
  • Posted on Nov 24, 2008
SOURCE: ryobi 31cc lawn trimmer carb adjustment
As with all 2 strokes if you have compression and a reasonable spark, you only need fresh fuel with correct oil ratio) and they must go !(as long as you haven't fiddled first and all gaskets are sealing) I start mine by(1) pumping the primer till it is firm,(2) full choke,(3) pull till it kicks ONCE,(4) half choke, pull till it runs,allow to warm up and(5) switch to run (you may need to apply a bit of throttle while pulling as in (4)(or give it a few more pumps if it dies) If all is ok, check that when properly warmed up there is a smooth transition from idle to full revs, if it hesitates it may need the LOW SPEED mixture leaning (clockwise) SLIGHTLY.If it dies the LOW SPEED mixture may need richening(anti-clockwise)(adjust 1/8 turn at a time) Make sure that motor is just peaking at full revs and is on the RICH side of peaking (HIGH SPEED mixture)(this will avoid seizing it Adjust both till it revs cleanly and is JUST rich at full, and idleing nicely and it should start without too much trouble.(If you have fiddled and are lost,-about 2 1/2 turns out from closed on both needles should get you started)
#1 Taper
Jim Parker
  • 1041 Answers
  • Posted on Jul 03, 2009
SOURCE: replacing fuel lines on ryobi 767r trimmer
The longest, and sometimes smaller in diameter of the two fuel lines, goes from the carburetor to the bottom of the tank. Leave enough slack in this line so that the filter that attaches to the end will rest comfortably at the bottom of the tank.
The other fuel line goes from the primer bulb to just inside the tank, (about an inch). make sure that you get the right size fuel lines. The plastic coupling goes on the end of this line, inside the tank. This keeps the line from pulling out of the tank.
(HINT): When feeding the lines through the tank holes, cut the lines at an angle. They will feed much easier into the holes. You can than cut them off square, once you know that you have enough to work with.
If you need further assistance, just let me know.
Jim
Anonymous
  • Posted on Aug 02, 2009
SOURCE: RYOBI weed eater.hard to start. starts then stops
I have a ryobi doule line bought in 1997..Had same problem put new gas cap on and problem solved..could not get air in....
rycgl
Roy Cagle
  • 1545 Answers
  • Posted on Aug 07, 2010
SOURCE: trying to replace the fuel line and the primer
The smaller line is connected to the fuel filter in the tank and goes on the carb body opposite the end with the hole in the cover. A larger diameter line coming out of the tank is the fuel return line and has the little connector on it just inside the tank to hold it in place there
It goes on the carb body (if primer is on carb) by the bulb.
If there is an external bulb...the small line is the same...there would be a larger line going from the carb body (nearest the end with a hole in the cover) to the smaller nipple on the primer bulb. A third larger diameter line would be connected to the larger nipple on the primer bulb and running to the little nylon connector inside the tank. This is the fuel return line and the smaller diameter line is of course the fuel supply line.
310BVR. What is primer/tank/carb gas line routing?
Hi:
Typical routing is
Tank to carb
carb to primer suction
primer out to tank return
Cheers
RYOBI 310BVR blower gas line from tank to primer to carb to tank diagram
the primer bulb has 2 out lets on it the short one feeds the car and the long out let feeds the tank Slice the hose to the tank and feed it intothe tank about 8 inches and hook out with a wire hook to cut the slice off and put on a new filter. Push it into the tank and be sure lays on the bottom of the tank..
I need the fuel/oil mixture for Ryobi 31cc 775r gas weedeater. Also the diaphram for the fuel line replacement.
The fuel/oil mixture is 40:1. That is 3.2 oz. oil/US gallon. Now for the fuel lines:
The small diameter line out of fuel tank (has filter in-tank on end) connects directly to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then "pushes" any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Again, on the primer bulb, the longer nipple has a line going directly from it to the tank. This is the return line. The shorter nipple on the bub has a line from it going to the metering chamber side of the carb. If the purge/primer bulb is on top of the carb...small line from carb body to small hole in tank with filter. Larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where sometimes the line is held in place with a nylon nipple connector that keeps the line from pulling out of the tank. Otherwise, the line should enter the tank for about 1/2" or so.
3helpful
I need a diagram for the fuel lines on a ryobi 31cc trimmer plus 15" from the fuel tank thru the primmer bulb to the carb for both lines
Don't quite understand your dilemma... there are only two fuel lines which go from the tank to the carburetor.....if looking at the engine from the back, the fuel line on the left is the intake line and the one on the right is the fuel return line....on the back of the carb are two fuel line brass inserts...they are inlet on left and return on the right....hope this helps ;-D
18helpful
Putting fuel line on right on ryobi 725r 15'' 31cc weedeater
Typical fuel line routing is:
One line (the one with the fuel filter in the end of it) comes out of the fuel tank2.gif and goes to the bottom fitting on the carburator. The second line comes out of the tank and goes to the bottom fitting on the primer bulb. The third section of line goes from the top fitting on primer bulb to top fitting on the carburator. Hope this helped and best wishes.
10helpful
1helpful
MY RYOBI 31CC 775R WEEDEATER WON'T START I REPLACED THE SPARK PLUG AND STILL NOTHING I DON'T THINK ITS GETTING GAS HOW DO I FIX OR REPLACE GAS LINES.
spary a little startingfluid in carb to see if it start if it start rebuild carb.to change fuel line
only if there dryrotted if it go thourght the gastank in little hold cut new line on a angle and thread through hold.hope helps you.let me know ok
Jul 24, 2009 • Garden
Top Ryobi Garden Experts
Jay Finke
Jay Finke
john h
Steve Sweetleaf
Steve Sweetleaf
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
