AK Techno Service Center is one amongst all the leading washer Service Center in Hyderabad and Secunderabad zones. laundry Machines unit most preferring a very common appliance at intervals the Market. Our Service Center offers the services for completely semi-automatic, automatic, full load and high load laundry Machines. Our absolutely fledged technicians will resolve any quite troubles for all firms (brands) of laundry Machines. Our master cluster of consultants provides the speediest and in addition the foremost solid service administration of any quite any washer in Hyderabad and Secunderabad zones. we tend to tend to in addition confer the coaching and data on removing the simplest execution from your model of the washer. Our qualified cluster is powerful and genial aside from giving ingenious repairs and administrations as per the ultimate inclination of the patrons. http://aktechnoservice.com/videocon-washing-machine-service-center-in-hyderabad
What is model #?
It would be good for you to call a plumber soon so that you can get your drain repair. Something could be clogging it and pushing towards further damage. A plumber would be able to help you out fairly easily since they do this all the time. https://www.completeplumbingdayton.com/drain-n-sewer.html
How To Fix A Washing Machine That Is Not Spinning or ...
removeandreplace.com/.../washing-machine-or-washer-dryer-is-not-spin...
May 15, 2013 - Washing Machine Service Repair Manuals Online Your washing machine is not working properly. It does not spin, won't drain, can't turn on, ...Washer Not Draining Water - Washing Machine Service ... - How To Fix A Washing ...
Washer Repair - Not draining or spinning ... - YouTube
? 5:17
https://www.youtube.com/watch?v=k41abYwM9WY
Jul 12, 2013 - Uploaded by ApplianceVideo.com
Washer Repair - Not draining or spinning - Repair & Diagnostic- .... off and my machine spins but it doesn't drain (high spin) does not work.
I appreciate your post, Rachel Kovach!
From my understanding your Frigidaire frontload washer is not spinning the final spinning and the clothes are still wet. If you washer is overloaded it will not spin properly to release the water out of the clothes. Also, a small load will cause your washer to not spin properly. You should additionally check the drain hose to make sure it not kinked or twisted that could cause your improper draining. If all that checks properly it could be an issue with your drain pump, motor, and control panel. I would suggest consulting with a technician for proper diagnosis and repair. This will help avoid unnecessary part purchases. -Matt
Hi friend, thanks for your post!
I see that your Frigidaire washer is not washing or spinning but everything else is working properly. I would advise you to check over the drain hose, make sure it is not restricted or too far down the drain pipe. If that checks out it could be a possible problem with your motor or control panel. One of those components could need to be replaced and for proper replacement I would recommend assistance from a technician to have a proper diagnosis completed. I hope this is helpful. -Matt
Hello friend, thank you for your post!
I understand that your Frigidaire washer will not wash or spin. Typically if your washer is not spinning it could be a potential issue with your drain hose. I would check to assure that there are no kinks in your drain line or that the drain hose is not too long. Those could be some possibilities.
If the drain line is clear you could be experiencing an issue with your timer or drain pump. I would recommend seeking assistance from a professional to come out and properly diagnosis your washer. I hope this helps. -Matt
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
