Ford Engine Bolt Torque Chart
Bolt Torque Spec Chart for Ford Engines
These specs are for stock-type bolts with light engine oil applied to the threads and the underside of the bolt head. Moly and other lubes offer reduced friction and increased bolt tension, which will affect the torque figure. If you use after-market performance bolts like ARP's, you should follow the recommended torque specifications.
260, 289, 302 Torque Spec.
Fastener Type
Torque Spec
Main cap bolts
60-70 ft-lbs
Outer main cap bolts
35-40 ft-lbs.
Connecting rod bolts
(40-45 ft-lbs. for 289 HP & Boss 302)
Cylinder head bolts
65-72 ft-lbs.
Rocker arms
17-23 ft-lbs.
Intake manifold bolts
23-25 ft-lbs
Oil pump bolt
23-28 ft-lbs.
Cam bolts
40-45 ft-lbs.
Cam thrust plate bolts
8-10 ft-lbs.
Harmonic damper bolts
70-90 ft-lbs.
Flywheel / flex-plate bolts
75-85 ft-lbs.
Pressure plate bolts
35 ft-lbs.
Front cover bolts
12-15 ft-lbs.
351W Torque Spec.
Fastener Type
Torque Spec
Main cap bolts
95-105 ft-lbs
40-45 ft-lbs.
Cylinder head bolts
90-100 ft-lbs.
Rocker arms
17-23 ft-lbs.
23-25 ft-lbs.
Oil pump bolts
23-28 ft-lbs.
Cam bolts
40-45 ft-lbs.
8-10 ft-lbs.
70-90 ft-lbs.
75-85 ft-lbs.
35 ft-lbs.
Front cover bolts
12-15 ft-lbs.
351C, 351M Torque Spec.
Fastener Type
Torque Spec
Main cap bolts
95-105 ft-lbs.
40-45 ft-lbs. (45-50 ft-lbs. For Boss 351C)
Cylinder head bolts
105 ft-lbs. (125 ft-lbs. For Boss 351C)
Rocker arms (non-adjustable)
5/16in. intake manifold bolts
21-25 ft-lbs.
3/8in. intake manifold bolts
28-23 ft-lbs
Oil pump bolt
25 ft-lbs.
Cam bolts
40-45 ft-lbs.
9-12 ft-lbs.
70-90 ft-lbs.
75-85 ft-lbs.
35 ft-lbs.
Front cover bolts
12-18 ft-lbs.
360, 390, 406, 427, 428FE Torque Spec.
Fastener Type
Torque Spec
Main cap bolts
95-105 ft-lbs.
Crossbolts for 406-427
40 ft-lbs.
40-45 ft-lbs. (53-58 ft-lbs. For 406 and 427)
Cylinder head bolts
80-90 ft-lbs. (100-110 ft-lbs. For 1963-67 427)
Rocker arm shaft bolts
40-45 ft-lbs.
32-35 ft-lbs.
Oil pump bolt
12-15 ft-lbs.
Cam bolts
40-45 ft-lbs.
70-90 ft-lbs.
75-85 ft-lbs.
35 ft-lbs.
Front cover bolts
12-15 ft-lbs.
429-460 Torque Spec.
Fastener Type
Torque Spec
Main cap bolts
95-105 ft-lbs
40-45 ft-lbs.
Cylinder head bolts
140 ft-lbs.
18-22 ft-lbs.
25-30 ft-lbs.
Oil pump bolt
25 ft-lbs.
Cam bolts
40-45 ft-lbs.
70-90 ft-lbs.
75-85 ft-lbs.
35 ft-lbs.
Front cover bolts
12-18 ft-lbs.
SOURCE: torque settings for pressure plate and fly wheel
the flywheel is 50 -60 ft.lbs....pressure plate is 15- 25 ft. lbs..
SOURCE: replacing front wheel barings on a 2005 chev
the big one tighten with a big bar and pull it to about 120lbs ,the three smaller ones which i cannot place at the moment but if they are 17mm size heads then about 60 but i always feel them as i do them and never use a torque wrench or a air wrench ,just muscle and 40yrs of feel
SOURCE: fly wheel torque specs
3.9L V6 5.2L & 5.9L V8's
flywheel bolts 55 ft lbs.
5.9L ( 24 valve ) 6-cylinder diesel
flywheel bolts 101 ft lbs.
8.0L V10
flywheeel bolts 55 ft lbs.
