Central Pneumatic is Harbor Freight's house brand.
For parts -
Harbor Freight Customer Service: 1-888-866-5797
Monday thru Friday, 5:00 am to 7:00 pm PST
Air leak through the top head exhaust port. • Nothing ... head valve or the seal located on the top of the cylinder (the part the driver ... Look to see if the piston top of the driver is aligned in the ... Solution: Remove and replace trigger valve (if.Missing: question
Keep your framing nailer in top working condition and save time and money with a ...O-rings that cause air leaks, a trigger valve that won't fire, or a leaking cylinder seal ...then replace the rings one at a time, matching each one to its replacement. Install the new bumpers, piston seals and piston stops and reinstall the cap.
Harbor freight does not sell parts for their nailers, however, parts for other nailers may work. Take your nailer to repair center and ask them to try matching parts. The orings are more or less universal and can be matched easily.
Unfortunately, harbor freight retires nail gun models very often. They only list the current nail gun models on their web site, thus manuals and parts are only available for a short time. The only help is that the new models are similar to the old. Sometimes the internal parts are the same but at least the user instructions should be the same. Download various manuals from similar models on their web site today and compare. Do not order parts unless you are sure about fit. As far as orings, you can use generic also from harbor freight (oring kits in standard and metric, not expensive).
Good luck
The Bostitch SX150 pneumatic brad nailer/stapler uses air to both drive the brad or staple and to return the driver/piston assembly to the top of the gun for the next firing. There is no spring that goes into the sleeve or under the piston. If your driver is not returning to the top of the gun you may have put an o-ring or seal in the wrong place or left one out. The o-rings and check seal on the bottom half of the driver sleeve are what control the air that returns the piston to the top so check those first.
Parts for central pneumatic guns are /should be available from Harbor Freight.com. Call their 800 number for information. If no joy, take your parts to Dewalt service center to try to match parts with Porter Cable framer. Porter cable parts are very close match to your gun. Good luck
we are not a parts service
