When that happens even if i choose another performance the UP1 upper sound 1 of that performance also keeps on playing as if using the sustain pedal, i just have to wait a minute until it's back to normal
SOURCE: when i am playing around
There are many possibilities. One is static discharge... those nasty little sparks when we walk across the rug and get zapped... or we scoot a little in our chair... one''s that you can;t even feel can send electronics into a tailspin.
Another is a possible overheating someplace in the unit. However if it comes back immediately when restarting this is usually not temperature.
Your description of the problem MIGHT indicate a problem with the D-A or digital to analog convertor chip... if so it will require servicing, probably at the factory or having a board swap by a service agent.
SOURCE: my korgx5d is not working
The power adapter may be failing... make sure you have the correct one. It sounds like the power may be marginal and when you start loading it including the sustain it gives out...More than this would be a very serious problem that would not have a DIY fix.
SOURCE: I plugged a sustain pedal
every sustain pedal got different polarity.. normally just go to global setting on your keyboard and change damper polarity setting to plus or minus (select which one work with your sustain padle).
