Archery Logo
mary feibel Posted on Dec 16, 2015
I need to find out what model my bow is. serial # 2307711
DL9 cl32 1/2 pw70 sL87 3/4
Fred Burkhardt
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Apr 13, 2016
Fred Burkhardt
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
3222
Points
Look inside the limb pockets or under the grip. most of my hoyt recurves were stamped under the riser grip. You'll find a set of #'s @ the base of the limbs but that's batch ID , draw weight , leanth. for just the bow limbs not the riser, ( talking recurve here) with a compound you'll prob. only find one set of #'s.
you will need a bow press to break down a compound.
good luck & good shooting
What year was a Fred Bear bow made that has writing on the riser 9R865 AMO-56 45#, ON THE LIMB IS PRINTED, BEAR GLASS POWERED GRIZZLY. The bow also has a copper BEAR medallion.
DATING YOUR FRED BEAR BOW
There are several features and changes that were made to the bear bows over the years that will help narrow the age of your bow or your potential investment.
1. The Serial Number: These bows usually have, what appears to be a hand inscription on one of the limbs that gives a serial number along with the length and pull weight of the bow. This serial number works very well for dating Bear Bows from 1965-1969 when the first digit of the serial number is the year of manufacture.
For example, a serial number of 5L212 would be a 1965 Bow.
Prior to 1965, the serial numbers for all Bear bows were started over every month, making these bows almost impossible to date by serial number alone. The "K" series of serial numbers (for example KZ9672) were started in 1970.
2. Patent Mark: Most of the BEAR Bows we have sold have the logo and the US Patents printed on it along with the date of CANADA 1953. This date that is printed on all bows made between 1953 and 1972 is simply the date of the patent for a working recurve limb and has nothing to do with the actual model year.
3. Decals & Silkscreening: In 1948 the small Running Bear decal was first and then was replaced by the large Standing Bear decal in mid-1953. The large Standing Bear decal also has the words "Glass Powered Bow" under the Standing Bear.
The large Standing Bear decal was used until 1955 when it was replaced with silk-screening the identification on the bows. By 1956 the silk-screening appeared on all bows.
4. All Wood vs Laminate: If your bow is ALL wood (no laminations of any kind) then your bow had to be made before the mass productions beginning in 1949.
  • If the ALL wood bow has a stamp that reads "Bear Products" in some form it would have been made before the early to mid 40's.
  • If it is stamped "Bear Archery" it would have been made AFTER the early-mid 40's and BEFORE 1949.
  • Also wooden bows with a small "Running Bear" decal can be dated to 1948
5. The Leather Grip: ALL Bear bows had leather grips until 1959. In 1959, the Kodiak Special removed the leather grip and in 1961 the Kodiak did the same, as well as the Grizzly in 1964.
6. The Coin Medallion: Beginning in 1959 all Bear bows had a coin medallion of one type of metal or another. Below are the approx date ranges for the type of coin used.
Copper Coin - 1959
Aluminum - 1960-1961
Pewter - 1962
Brass - 1963 - 1970
Nickel-Silver - 1971-1972
ALL coins were flush with the wood until 1972. In late 1972 the coin was raised above the surface of the bow and came in both gold and chrome covered plastic and are still used in Bear bows today.
7. Manufacturer Location: in 1978 Bear moved all manufacturing and offices to Gainesville, Florida. If your bow shows Gainesville on it then it was made after 1978
8. Model Of The Bow: Check the Model of the bow. Below is a yearly production chart for the most popular Bear Bows.
Wood Handle Take-Down 1969-1972
Wood C-Riser Victor Custom 1973-1975
Magnesium Handle Take-Down A-B-C 1971-1978
Kodiak Static Recurve 1950-1953
Kodiak Recurve 1954-1966
Super Kodiak 1967-1976
Grizzly Static Recurve 1949-1957
Grizzly Recurve 1958-1978
Super Magnum 48 1966-1976
Kodiak Magnum 52" 1961-1977
Kodiak Hunter 58" and 60" 1967-1977
Tamerlane 1962-1968
Tamerlane HC-30 1965-1967
Tamerlane HC-300 1968-1972
Kodiak Special 1955-1967
Temujin 1968-1970
Tarter 1968-1972
Victor Patriot 1973-1977
Victor 1972
Polar (recurve) 1957-1970
Alaskan (leather grip semi-recurve) 1959-1961
Alaskan (recurve) 1966-1970
Tigercat 1964-1978
Bearcat 1964-1971
Black Bear 1972-1978
Little Bear 1965-1978
With this information you should be able to get really close to dating your Bear Bow if not pin-pointing it to the year.
I need information on this compound bow I bought,,, It is a 79lb Golden Eagle Pro Thec serial number 1845865,,,, can someone show me some light on this item
Hi, you can find most of the compound bow on this online marketplace: Compound Bows Compound Bows Kits Package on Sale Atbuz
On each product detail page, you can find the product description and detail.
Free shipping and free return on eligible items!
Oct 08, 2017 • Archery
Draw length adjustment on an old browning explorer 2 compound bow serial number y1b 3995
hard question lots of explorer 1 s
just pulleys and bow string
explorer two same system
if a 1960s bow 47 inch tall 55- 70 pounds approx
Sep 17, 2016 • Optics
2helpful
I can't get it to bow or rifle mode
Look on the back of the rangefinder......Its a very small strip that has the model number, serial number, and date of manufacture. If it sez.....20-1932 you have a "bow and rifle" rangefinder.....!!!! If it doesn't have model number 201932. You don't have that capability. Read your manual, check the unit for the model type.
Part 2: Try holding down the "FIRE BUTTON" for more than 5 seconds....see if the the "setup" comes across the display screen........(read the manual) The unit should have came with a ballistic disk. If you don't have one call Bushnell and get one. (800.423.3537) It has a lot of good info on it.
Good Luck to you David!!!
mr tech geek
dont forget to rate....
9helpful
Year made MKAD2674059 minn kota
According to: http://www.northlandmarine.com/MinnKotaMotorControlBoardAssm.htm
*Note: Newer model trolling motors have serial numbers beginning with the two-letter prefix MK (Minn Kota), followed by a two-letter year code. MKAB .......... 2001
MKAC .......... 2002
MKAD .......... 2003
MKAE .......... 2004
MKAF .......... 2005 MKAG .......... 2006
MKAH .......... 2007
MKAI ............ 2008
MKAJ ........... 2009
MKBA .......... 2010 A serial number with the designation MKAB denotes a
2001-motor and MKBA would be a 2010-year model
Can't open it to put in new batteries
Just cracked it open by clearing the edges with a exacto knife.
7helpful
6answers
Needs Access Code
on all these machines it is universally ***1
Top Archery Experts
Kardoc
ADMIN Andrew
ADMIN Andrew
Are you an Archery Expert? Answer questions, earn points and help others
