Beyerdynamic T51P Tesla Headphone - Silver Logo
Gavin Sayer Posted on Dec 16, 2015
How can I rewire the drivers?
Complete cable replacement
2answers
How to rewire Delta AP 400 dust collector to 220 Volts
To rewire a Delta AP 400 Dust Collector to 220 Volts, you will need to obtain the right wiring and circuit connectors. You may need to consult an electrician or technician to complete the job safely.
How do I rewire a cut harness car radio of a chrysler town country 2010
If you have original cables match pins. Otherwise there should be a diagram or table (paperwork) explaining where to wire in the new to old wires.
Passenger window will not go up
Whenever a modern vehicle with electric doors and electric windows ages... whatever door is used the most will wear out the wires in the wire bundle going through from the door to the chassis. Sometimes i rewire the controls so that only the driver or only the passenger can operate the window. Sometimes i run some new wire splices to replace the broken wires. I have seen damaged switches and or damaged cables or tracks on a particular window. So if the cable and mechanical look ok then it has to be a wiring issue.
The accelerator wire has come undone and broke. how do we rewire it
You can not rewire an accelerator cable you have to have it done by the experts. You go to cable makers you can actually take out the cable yourself if you know a little bit of mechanics. Check in your local directory and see cable makers they do all cables including the clutch cable.
REWIRE SPARK CABLES 95 CHEVY CORSICA V6
Hi, I am not aware of your skills level, however, some office "WHITE OUT" or white paint etc will vastly assist you to complete the task successfully. Pick a lead in the cap, mark it's location with a dab of white out / white paint, follow the wire, (HT lead) to it's spark plug, very carefully remove the spark plug connection and / or rubber boot if fitted. fit the replacement lead and route it back to the cap. Carefully remove the original cable and fit the replacement. Do the same for the rest of the cables,(HT leads) marking the cap as you go, ie, a,b,c,d or a number sequence your choice.. Remember, doNOT remove all cables at the same time. Change out one at a time, and you will not mix up the firing order.
It is a wise precaution to replace the cap and rotor,when you replace the cables, (HT leads.). .
Good luck.
How to rewire voice coil of a speaker
You cannot rewire a voice coil of a speaker unless the speaker itselfis rebuildable. If it is rebuidable, a complete reconing kit is necessary
Broken vga cable
If the cable is to a CRT monitor this will require and new cable harness to be rewired to the main board of the CRT which will cost a lot to replace if the cable can be obtained usually not successfully due to the fact that most CRT monitors are manufactured in Asia.
Reason 4 won't let me play anything. At first i thought it was because I had the wrong Audio driver selected. But,as it turns out I can't select an audio driver unless reason is a master to ReWire. how do...
Hey , make sure every other music program is quitted completely . then quit reason , re-open and in preferences change from No Audio into what ever output you're going through.
hope it helps.
Need to rewire entire jeep
If you want to rewire the vehicle, assuming that you will not be changing any systems, you can usually find complete new wiring harnesses from both the dealer and from aftermarket selllers like Quadratec and JC Witney.  Buying the complete wiring harnesses will be alot cheaper and less time consuming than trying to make them yourself.  These wire assemblies are just a plug and play deal, you disconnect a harness and replace it with the new one.  They may even include some instructions. If you need further assistance with custom wiring or diagnosis, I would recommend getting the service manual for the vehicle from the dealer or used ones from eBay ($30- $100).  The factory service manuals have complete wiring diagrams and schematics as well as full diagnostic information.  These service manuals are NOT like the ones found at your local parts store (Chilton or Haynes).  The factory service manuals are like complete blueprints for a car.
Top Beyerdynamic Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you a Beyerdynamic Audio Player and Recorder Expert? Answer questions, earn points and help others
