Only run one time for 2hrs.
SOURCE: Some tapes will start and immediately shut down
the vcr is on threshold of belt life. try replacing (or cleaning with alcohol) the take-up reel belt. The vcr has a built-in time-out feature to protect the video tape. if it takes too long for things to happen, shut-down occurs.
SOURCE: engine keeps shutting down
Most Honda engines have an oil pressure switch that prevents engine damage due to low/no oil pressure. Make sure there is sufficient oil in the engine and that the wire is connected to the pressure switch.
SOURCE: onan 4000 start good runs only ten minutsand shuts down,starts up
First locate the oil pressure switch and see if you can bypass it,then see if it runs. If not check the fuel filter and fuel pump,make sure solonoid for fuel pump is kicking on.
SOURCE: engine starts dies down immediately.fuel is ok spark plug ok
Most likely the carburetor is not ok. An engine does not just DIE. If you press the prime bulb, does fuel squirt in carb. If it starts the runs for about 3-5 seconds then dies, there is most likely a float or needle shut off problem. Or it could be as simple as a clogged carburetor. It only takes one tiny peice to clog one. Take the carb off and make sure all jets( small holes in carb) are clean. Mike. Rate 100% please.
SOURCE: Starts, runs a few seconds then shuts down. Will
Check for a low lube oil sensor problem first. Could be low oil pressure or a failed sensor. The sensor is timed and if pressure doesn't come up, then unit is shutdown.
Check fuel filter and also air leaks in the fuel supply lines.
Check if the fuel shutoff solenoid is responsible for the shutdown. If it closes just before the engine quits, then it is being commanded to shutdown, probably as a safety interlock.
Testimonial: "Very good info. I don't think I have a fuel shutoff seloniod unless it's internal to the injector pump."
