LED TV Wont Turn on, just shows red indicator light
The TV has had problems turning on... When plugged in, indicator light shows red. when pressing the power button, tv doesn't come on. Would have to unplug from power, wait a few minutes, and re-plug tv back in and try power button.. Normally this would work and indicator would turn blue. If tv doesn't show Sceptre Logo screen after 5 seconds, tv doesn't turn on. if it does great.
Now tv isn't turning on 95% of the time. and if indicator does show blue, 10% chance tv turns on.
any suggestions?
Re: LED TV Wont Turn on, just shows red indicator light
What if you have the Same issue but replacing the Power Board did not fix the issue? It just shows the red light. Once the Power button is hit then the red light disappears and never comes back untill you replug into an outlet, and the TV still wont come on?
It indicates that the TV is not receiving enough power to operate normally.
The power cord or outlet might be faulty or loose. Try plugging the TV into a different outlet or using a different power cord. Make sure the cord is firmly connected to the TV and the outlet.
The TV might have a blown fuse or capacitor. This would require opening the TV and replacing the damaged component. This is a risky and complicated procedure that should only be done by a qualified technician. Do not attempt to do this yourself unless you have the necessary skills and tools.
The TV might have a software glitch. Try resetting the TV to its factory settings by following these steps:
Turn off the TV and unplug it from the power source.
Press and hold the power button on the TV for 10 seconds.
Plug the TV back in and turn it on.
If the TV shows a menu, select the option to restore factory settings. If the TV does not show a menu, repeat steps 1-3 until it does.
Try a reset. Start by unplugging for 1 minute, then plug back in & if still won't restart try the following. If none of the following work, you will need a technician.
Initializing the TV in many cases can remedy a problem.
In the 2006 product line Initialization is now a user function.
Pressing the front panel "INPUT' and "FORMAT"
buttons at the same time activates Initialization. When
complete all user settings will have to be set again. The
table in Figure 4-3 list the User Initialization procedures.
Note: Pressing INPUT and FORMAT is the same as
the Initialization in the Option Menu (MENU-2-4-7-0)
Order Name Procedure Results Notes
1 System Reset Press <System Reset>
on Front Panel
Hardware & TV operating
software reset.
POWER/Timer LED flashes for 60
seconds. No customer settings
are changed.
2 User Initialization
Press <INPUT> &
<FORMAT> on Front
Panel at the same time.
All customer Audio &
Video settings are reset to
factory default.
All customer settings will need to
re-configured.
3 Reset System
Defaults
From the remote, press
<MENU> <1-2-3>
<ENTER>
except V-Chip are reset to
factory default.
Netcommand, Channel Memory,
etc., will need to be re-configured.
SERVICER
PROCEDURE 4 Initialization
<MENU> <2-4-7-0>*
select "INITIAL" press
<ENTER>
All customer settings are
reset to factory default.
re-configured.
MITSUBISHI RESET / INITIALIZATION CHART
CUSTOMER
PROCEDURES
Figure 4-3
Figure 4-4
LED Indications
The front panel LEDs, refer to Figure 4-4, also assist in
determining the cause of a symptom. Figure 4-5 illustrates
normal LED operation. Figure 4-6 shows the
LEDs response when a problem is detected and indicates
the possible cause.
Power/Timer
Indicator
Status
Indicator
Lamp
Indicator Condition
Off Off Off Off (standby)
Blinking green
fast Off Off Initialization (10 - 65 seconds)
Off Off Blinking
green fast Lamp runs for 1 min after PTV off
Green Off Off Power On
Blinking green Off Off Power On Timer is set
NORMAL LED INDICATIONS
Power LED Status LED Lamp LED Condition
High Temperature - check ventilation air flow.
(Temperature sensor is disconnected.)
Off Off Blinking yellow Lamp cover is open.
Lamp failure (Lamp fails to turn on)
Off Off Red (Lamp turns off after lighting)
Lamp is broken
Off Blinking Red Off Fan Stop
Off Red. Off Circuit failure. (Run Error Code Check)
Re: Bravia KDL46EX720. Red LED blinks 4 times and TV wont turn on. What is the problem?
Do a Power Reset.
1. Turn off the TV.
2. Unplug the power cord of the TV from the electrical outlet.
3. Let the TV remain without power for 60 seconds.
4. Plug the power cord back into the electrical outlet. (If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.)
5. Turn on the TV.
If the issue still persists after performing power reset, that may be an indication that the TV needs service. You may refer to this linkto locate the nearest Sony authorized service center in your area.
Setup codes to check with Samsung TV are: 0105 0077 0076 0109 0007 0009 0004 0005 0085 0172 0942 0358 0012 0015 0080 0104
0106 Direct Code Entry
Press and hold the SETUP button until the red indicator stays on, then
release the SETUP button.
Press and release the desired Mode button (TV, VCR, etc.). The red indicator
blinks, then stays lit.
Enter the 4 digit code from the code tables. Note: after a valid code entry,
the red indicator turns off. For an invalid code, the red indicator flashes.
With your device on, press CHANNEL UP. If the device responds, no further
programming is required. Note: If some buttons do not operate your device, try
one of the other codes for your brand.
Code Search If after trying "Direct Code Entry" your device does not respond, or if your
brand is not listed, try doing a search of the code library for your code by
following these steps.
Manually turn on the device (TV, VCR, etc.) to be controlled.
blinks once, then stays on.
Press the CHANNEL UP button repeatedly (up to 300 times) until the device to
be controlled changes channel. The red indicator blinks, then stays lit.
Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes
under CBL, etc. If you want to store a VCR code under CBL, etc., first follow
the procedure for Direct Code Entry and press CBL in step 2 of Direct Code
Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the
steps above for Code Search.
IDENTIFYING CODES FOUND USING THE SEARCH PROCEDURE
Press and hold the SETUP until the LED indicator lights steadily. Release
Setup button.
Press the mode button that matches the equipment you want to identify. The
LED blinks once.
Press and release SETUP. The LED blinks once.
To find the first digit, press each number button from 0 to 9 until the LED
blinks. The number you pressed is the first digit of the code.
Press each number button from 0 to 9 again as above to find the second
digit.
Press each number button from 0 to 9 again as above to find the third digit.
Press each number button in turn to find the fourth digit. When the fourth
digit has been found, the LED goes out.
Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search Method
Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
Press and hold the SETUP until the LED indicator lights steadily. Release Setup button.
Press the mode button that matches the equipment you want to identify. The LED blinks once.
To find the first digit, press each number button from 0 to 9 until the LED blinks. The number you pressed is the first digit of the code.
Press each number button from 0 to 9 again as above to find the second digit.
Press each number button in turn to find the fourth digit. When the fourth digit has been found, the LED goes out.
I had the same problem. all the service reset would only make the display come on for a few second with no "k" on the screen - only the channel would show up. I purchased a complete set of board for the lcd on ebay, and started swapping them one by one. The inverter boards were the culpret. Tele working 100% since that board swap.
Make sure you try every code in the list for your JVC TV. The codes for your Jumbo Universal Remote to control a JVC television are 013, 054, 055, 060, 065, 067, and 089.
To program your remote by entering a code, follow these steps:
Turn on your TV.
Press and hold the CODE SEARCH button for at least 3 seconds until the red LED lights up and stays lit.
Press the TV button on the remote so that the LED blinks once and then remains solid red.
Enter the first set of 3-digit codes from the list. The LED will
blink once every keypress. After the 3rd digit, the red LED will turn
off indicating that the code was recognized for the device. If the code
was not compatible, the LED will flash several times and you need to
return to step 2 to try that code again or to try the next code in the
list.
After the LED has turned off, aim the remote at the TV and press
ON/OFF. If the device turns off, you have used the correct code and the
remote was successfully programed. If the device does not power off,
return to step 2 and try again with the next code in the list.
To have the remote try each TV code it knows one at a time, follow these steps:
Turn on your TV.
Press the ON/OFF button slowly and repeatedly until the TV turns off. The LED will blink once each time you press the ON/OFF button.
Once the TV turns off, press the ENTER button to store the code and the LED will turn off.
To program your remote by entering a code from a manufacturer's list, follow these steps:
Turn on your TV.
list.
Turn on your TV.
ON/OFF button.
The power red led indicates that your device is "power on" , but the status led still red and turn to green if the device ( video input )received video signal ( from DVD player, Laptop etc. ) .
