HOW DO I RUN AUTO SCAN
First make sure that the Source is set to TV and a good antenna/coaxial cable is connected to the TV. Use the Input button on the TV (to the left of the power button) or the Input Select button on the remote. Use the up/down arrow keys to navigate through the source list and press Enter to select that choice. (On the TV, the Input button is the Enter button.) Next press the Setup/TV Menu on the remote (or Menu on the right arrow button or Enter. Then go down to Auto Ch Memory and press the right arrow or Enter. With the up/down arrows, navigate to Signal Type and set that to Air (for OTA channels) or Cable with the left/right arrows. Now navigate to Automatic Search and press the right arrow or Enter. Wait for the scan to be completed.
I hope this helps. The steps are shown in the manual for the LT-19D610 on page 18. The manual is available from JVC on the product page: http://support.jvc.com/consumer/product.jsp?modelId=MODL028825 . The direct link to the manual is http://resources.jvc.com/Resources/00/01/47/J55D0221B.pdf .
If you have already run the Auto Tuner as part of the quick setup earlier in this guide, please
skip ahead to "Channel Summary" to continue setting up your television. In Auto Tuner Setup,
the TV automatically scans through all available channels, memorizing the active ones and
skipping over blank ones or channels with weak signals. This means you scan using the
CHANNEL +/- buttons), you will receive only clear active channels.
Press the MENU button
?† To AUTO TUNER SETUP
?® To operate
?® To choose CABLE or AIR
Press the OK button to start
Initial Setup
Auto Tuner Setup
Programming will take approximately 1 to 2 minutes. The auto tuner is finished when the
message PROGRAMMING OVER! appears onscreen.
Channel Summary
Channel summary allows you to customize the line-up of channels received by your TV. You
can add or delete channels from the line-up or prevent any unauthorized viewers from watching
any or all 181 channels.
?† To CHANNEL SUMMARY
?® To operate
The Channel summary screen will now be displayed with
the channels set to scan marked with an "?". You can delete
channels from the scan by removing the "?". If any channels
were missed during auto tuner setup and you wish to add
them, you may by placing an "?" next to the channel number.
?† ?® To the SCAN column
Press the OK button to include or delete from scan
Press the MENU button when finished
You can block access to a channel by activating the channel lock.
?® To operate
?† ?® To the Lock Column ( )
Press the ZERO button to lock or unlock that channel
AUTO TUNER SETUP
CABLE
If you wants any codes, contact me through Fixya. Ok
I'm quating these procedure from the manual I've with me, and it is for JVC AV32S565.
