Toys Logo
A
Anonymous Posted on Dec 01, 2015
I have a 5 foot singing Grinch that I cannot get into the standing position. I have pushed down on his shoulders and releasing gently. I've searched for a dial on Neck to turn and cannot locate
Claude Kayser
Level 3:
Top Expert:
  • Master 9,098 Answers
  • Posted on Dec 01, 2015
Claude Kayser
Master
Level 3:
Top Expert:
Answers
9098
Questions
0
Helped
5065853
Points
28436
I have a 5' Singing Dancing Skeleton by Gemmy Industries
ebookss.holding.no-ip.ca/F/support/t6410955-5_singing
I have a 5 ft tall singing dancing santa claus that was from Walmart. ... christmas(Gemmy 5 ft Animated Mr. Grinch Singing Dancing as Santa )who I cannot get out of ... My Gemmy Singing, Dancing Santa won't spring up into standing position.
15235022 Penguin won't dance - Document Download
codigo.no-ip.net/F/support/t15235022-penguin_won_39_t_dance
... you turn to unlock him into the standing position. good luck , I have the same problem. ... I have a 5 ft tall singing dancing santa claus that was from Walmart. ... 5 ftAnimated Mr. Grinch Singing Dancing as Santa )who I cannot get out of the ...
I have a lifesize grinch who stole christmas(Gemmy 5 ft - Fixya
How do I extend the gemmmy singing Santa Claus to full height?
To extend the height of your Gemmy Singing Santa Claus, you can follow these instructions:
Carefully remove the product from its packaging and unpack all contents.
Lay the figure on its back and locate the locking pins underneath the figure base. Turn pins counterclockwise to unlock. Remove pins and retain for later use. Pins are used to secure figure in compacted position for storage purposes only.
After pins have been removed, return figure to upright position. Place on a stable, secure, and flat surface.
Gently press down on figure's shoulders and then slowly guide body upward to full standing position. Do not press down and release without holding the figure's shoulders.
The figure's head is located under the body, it will be revealed once you guide the body to full standing position. Attach the figure's head by aligning the groove and setting in place. Make sure the latch locks the head in place.
Pose arms in desired position.
Adjust volume control to desired level.
Please note that these instructions are for a general Gemmy animated holiday figure 1. If you have any specific questions or concerns regarding your product, please visit www.gemmy.com for customer guidance or contact Gemmy at 1-800-231-6879 .
Oct 28, 2023 • The Toys
2answers
My life size Santa stopped dancing. How do I fix?
The first step would be to check all of the connections. If they are fine, next is to check the power supply for voltage using a meter.
Santa will not click down or stand all the way up what is the problem
Hi Penny,
Did you try pushing down on his shoulders? If you remove the screws from the base and apply pressure to the shoulders he should able to move into an upright or down position. If that doesn't work try looking at the instructions. Maybe they will help you take it apart: http://www.fixya.com/support/p1879030-gemmy_gemmy_life_sized_animated_santa/usermanual-A057EBE-pdf
11helpful
3answers
I have a lifesize grinch who stole christmas(Gemmy 5 ft Animated Mr. Grinch Singing Dancing as Santa )who I cannot get out of the sitting position..... [email protected]
if you have the same on as I do, gently pull off his head - there is a large dial that you turn to unlock him into the standing position.
good luck
3helpful
2answers
I do not know how to pull the top part of a 5 foot animated santa from the bottom part.my wife always did it and she died and i don't have the instructions..
It is suposed to pop up once you press on its shoulders. Once you press them both down you will hear two clicks and release and it will pop up. Mine was jammed and when I pressed it down on the shoulders only one side would click, the other side would not click so Santa did not pop up to full size.
It was jammed on the white area of the stocking, the material got tucked inside the click mechinism prevent it from making proper contact. To fix it I simply pulled the white stocking material up (as if you are going to roll the pant leg up) and then when I pushed the shoulders down after that it opened up just like it should!
I have a 5' Singing Dancing Skeleton by Gemmy Industries purchased at a WalMart...Lost instructions to unlock it into standing (non-storage) posistion.
Remove the locks from the bottom. They look like the base for one of those solar lights you put in your yard. Once they are removed, push down on both shoulders at the same time and it will spring up! Hood luck and Happy Halloween!
Oct 14, 2010 • Toys
2helpful
3answers
I need instructions on how to pop up my gemmy animated singing santa
Top Toys Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Toy Expert? Answer questions, earn points and help others
