Pride Mobility Jazzy 1121 - USA TechGuide
www.usatechguide.org/itemreview.php?itemid=570
19 posts - 16 authors
Medium Back Seat Contoured Medium Back (standard). ... Comments: My jazzyscooter goes forward and side to side but the reverse makes a quick .... Strengths: Tough chair - town I live in doesn't have many curb cuts, but chair will climb ....Maneuvers poorly through (Handicap) doorways, due to rear locked caster wheels.
I suggest you print this out and keep it handy.
Locking/Unlocking the VSI
The VSI has a feature that enables you to
lock your power chair to prevent unauthorized use.
To lock the VSI:
1. With the VSI switched on, press and hold the on/off key. After 1 second, the VSI should beep.
2. Release the on/off key.
3. Push the joystick to the full forward position until the VSI beeps.
4. Pull the joystick to the full rearward position until the VSI beeps.
5. Release the joystick. There should be a long beep.
6. The VSI is now locked.
To unlock the VSI:
1. Press the on/off key and power on the VSI. The maximum speed/profile indicator should ripple up and down.
2. Push the joystick to the full forward position until the VSI beeps.
3. Pull the joystick to the full rearward position until the VSI beeps.
4. Release the joystick. There should be a long beep.
5. The VSI is now unlocked.
NOTE: If the above procedure fails to either lock or unlock the VSI, contact your authorized Pride Provider.
