- Press and Hold the trip odometer button while turning key to position 1 (ACCESSORY)
- Keep the button depressed (about 5 secs.) until you see "Oil Service" or "Inspection" with "Reset" or "Re" in the display
- *Note: On vehicles with "High" cluster, you will also see the amount of fuel (in litres) remaining until next service
- Press the button again and hold for approx. 5 secs. until "Reset" or "Re" flashes
- While the display is flashing, briefly press the button again to reset the Service Interval. After the display has shown the new interval you should see "END SIA" for about 2 secs.
Note that if the "Reset" or "Re" does not flash, then you have not met the minimum consumption level and cannot reset.
blows fuse, loss of transmission shifting automaticly, loss of heat gauge, fuel gauge, loss of speedo gauge, loss of overdrive . fuse blows when put into gear. ten amp fuse.
You need to go to the support section of the Pentax website and engage in a live chat with a service tech using your computer or even a phone conversation to resolve your problem.
Your power supply has burnt out which unfortunately is extremely common in new devices. I do agree that it may be worth fixing if it is only couple years old.
On your instrument panel directly below the rev counter are 5 buttons.
Press and hold button A for approx 5 secs, all the digits will flash
Realease button A
Press button B to change from KMH to MPH
Confirm this is what you want by pressing A for 5 secs
Hope this helps you out. Happy riding
