Hitachi P50H401 50 in. Plasma HDTV Logo
Tammy Kidd Posted on Nov 28, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Tv repair.for plasma tv
How to take off screen boards
Kaye Day
Level 3:
  • Master 744 Answers
  • Posted on Nov 28, 2015
 Kaye Day
Master
Level 3:
Answers
744
Questions
Helped
223078
Points
13385
No screen boards found. Do you mean any of these?
Types of TV Boards Every TV uses a collection of various boards to perform every function imaginable in a television. The boards work together to produce sound and images on a television screen. When certain mechanisms in a TV fail, it might be time to start testing different boards to see if they are functioning properly.
Main Board
The main board is the central hub of a television circuit system. The easiest way to identify a main board is to find the board with the various video and audio inputs/outputs. Generally speaking, main boards also contain a tuner, HDMI, USB, and S-video port. Main boards are one of the largest boards in a television. Main boards might also be referred to as a motherboard, main module, or an A/V board.
Power Supply Board
Another large and important board inside a television is the power supply board.. Usually found in the center of the TV, the power supply board has several connectors that supply power to the other circuit boards. It can contain transformers, large capacitors, and integrated circuits. There is usually a table on the power supply board indicating the different voltages it produces in addition to the signal names.
Inverter Board
Found on LCD TVs, inverter boards are used to mount the LCD backlight. These are smaller boards, usually shaped like long thin rods. If an LCD TV's screen is dark, distorted, or difficult to see, it can be the result of a defective inverter board. Inverter boards fail when inadequate power is not allowing current to pass through the backlight bulb.
Timing Control Board / Logic Board
The timing control board, known as the T - CON board,, is typically only found on LCD and LED TVs. Plasma TVS, on the other hand, use a logic board.. The functions of the logic and T-CON board are similar, as each functions to digitize the information it receives from the TV's processor. This allows the screen to display images on the pixel level. When the T-CON or logic board fails, the screen images may become distorted, leading to pixelation and the appearance of lines on a television. On a logic board, there are slotted connectors on all four sides, while T-CON boards have connectors on just two sides.
X-Sustain and Y-Sustain Boards
Also known as the X-SUS and the Y-SUS, the x-sustain and y-sustain boards only appear in plasma screen TVs. The x - sustain board might also be called the Z-SUS. These boards function similarly, producing proper screen images. Although they serve pretty much the same function, the two boards work independently of each other. The x-sustain board activates all the display lines at once, while the y - sustain boardaddresses all the individual lines of display. When one board breaks down, it probably will not affect the functionality of the other. However, it might be a good idea to have both replaced because X-SUS and Y-SUS boards have a relatively short life span anyway. A failure of one could mean an impending failure of the other.
Buffer Boards
B uffer boards are also only found in plasma screen TVs. Connected to the y-sustain board, a buffer board works to turn output to the plasma display. Common defects of buffer boards include the burning and shorting of power lines.
TV Boards Buying Guide
Soniq PT42SH plasma TV power on. No back light and no pictures
SONIQ LCD TV REPAIR Blank flickering screen Energy ...
? 1:32
https://www.youtube.com/watch?v=FUqdi7lwmcE
May 29, 2013 - Uploaded by WastedOne2
Fix ya Soniq Tv once loaded up hit menu button then channel + then ... SONIQ LCD TV REPAIR Blank flickering screen Energy Saving Mode Issue ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't turn on] ... Common easy LCD TV fix: bad picture screen rainbow colors - Duration: 4:04.
No Image & Blank Black Screen Flashlight Test - YouTube
? 5:56
https://www.youtube.com/watch?v=xUzCLgoSPGM
Sep 15, 2014 - Uploaded by ShopJimmy.com
LCD & LED TV Repair - No Image & Blank Black ScreenFlashlight Test - How to Fix LCD & LED TVs ... Most LED TVs will have a t-con board, a power supply board, a main board and an LED ..... SONIQ Australia 1,718 views.
Soniq PT42SH plasma TV power on. No back light and no ...
I have Lg 50pc3d-ud and it has very dark spots on the tv that moves around. The screen is also very dark no matter the settings. The dark spots aren't always there, they go away sometimes but if...
This problems ur tv are having only can be two causes 1) The Y-Sustance main tuner logic board or 2)The tv Plasma screen panel itself it is slowly leaking radiaton and dying,if it is the tv plasma screen panel itself it is dying than the tv not worth repairing because by replacing the plasma screen panel itself will cost the same as a new tv itself.The Y-Sustance board-that the tuner main logic board that take in the tv incomming broadcasting signal cable.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish Y-Sustance main tuner logic board for replacement.This tv problems are 50/50 between the Y-Sustance main tuner logic board or the very exspensive plasma screen panel itself.
Tv was on then had color spectrum full screen then it went black with space at top of screen 50 in plasma insigna
there are several board in plasma tv which can cause this kind of problem. there is Y board, there is X board & the plasma panel itself may be faulty. u need to replace both boards one by one to get the problem solved. if replacing both boards not solves, then u have to replace the PANEL which is a costly repair.
2answers
Problem with the LG 42PC3D 42 in. Plasma Television Horizontal half black screen, sound is still there
Sorry this tv it is not repairable because the tv Plasma screen panel itself it is the tv problems and the causes,this tv only can be repair by replace the whole new tv Plasma screen panel itself only not practical.Because the tv Plasma screen panel are 90% inportant to the tv functions and the cost of the tv.By replacing the tv Plasma screen panel will cost the same as a new tv.
2answers
I have a five year old Vizio P50HDTV20. While watching it the other day the center 1/3 of the screen went black from top to bottom. The left third and right third are fine. This condition persists with...
Sorry the problems,ur tv it is having,it can't be repair,the tv Plasma screen panel itself it is shorted and dead,that why the tv plasma screen panel have only a third of the plasma screen panel it have a good clear picture and the other 1/3 of the tv plama screen panel is black and dead.The tv that have a broken or shorted dead plasma screen panel it is not worth repairing,because only way repair it is by replacing the whole entire plasma screen panel itself.The tv plasma screen are about 90% of the cost of the tv and can't buy it anywhere else except the tv corporations dealers themselves.Sorry tv now,only can be salvages for those electronic boards for parts that it.
2answers
I HAVE AN LG PLASMA TV APPROX 7 YEARS OLD HALF THE SCREEN IS BLACK?
Deal with this problems before.Sorry,tv some how the plasma screen itself,it is shorted and plasma screen it is dead.This problems ur tv have it is nothing to do with it elctronics boards problems.This tv it not repairable except by replaced the whole plasma screen as u know the screen are 90% important to tv and in limited in production by the tv corporation.Nowhere to buy the screen,but except the tv corporations themselves.By replacing the plasma screen,will cost the same as a new tv.
My picture splits in half. Top is good, bottom is black
Sorry,this problems can't be repair.The Plasma picture screen itself it shorted and dead.The Plasma screen panel it self,will cost the same as a new tv.The picture screen are 90% of the tv and it limited production buy the tv corporations.Sorry,now the tv dosen't worth as a whole tv anymore.Take the tv aparts take out all the eclectronics parts and boards sell it for spare parts,like on Ebay.com to make some money back and help some body else out for spare electronic boards problems.
My TV screen turns green with no picture until i turn it on and off TV is approx. 2.5 yrs old and is used very little and it seems to be getting worse thanks Kent
This tv a CRT tube tv?Or a LCD tv or a Plasma tv?The tube tv,the video board that connect to the CRT tube head have problems.The Plasma or a LCD tvs.The main board,call the Tuner board is the cause,this board,that where the incomming broascating signal cable plug into it.CRT tube tv,old technology,must take to tv shop for estimate and repair.Plasma or LCD tvs can tries websites like Shopjimmy.com or Ebay.com to buy a refurbish Tuner board for the replacement.
I have a jvc plasma...apparantly it got banged while moving and now when i turn it on it has a place that looks like a crack but isnt and then thses weird "plaid" designs....can this be repaired?
No,the Plasma tv screen is cracks and damage.Take an insurance claim against the moving company.Sorry the plama screen is 90% of the tv,even u can buy the plama screen from the tv company to repair.They will sell the Plasma screen to u the same as a new tv.Even might cost more after the new plasma screen it put in.Now the tv only worth as for salvage electronic boards parts only now,not as a whole tv anymore.
1helpful
I have a 42 LG Plasma TV with a broken screen
NO....You must pay attention to all numbers on the back of the TV. Verify these with your tech or contact your LG customer support for the correct board numbers. If the screen was broken I doubt if you can repair this for less than it cost to replace. The screen for this one runs at about $650.00. Good Luck and good advice!
Top Hitachi Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
