Singer 9960 - 9960 Quantum Stylist Logo
t
tami Posted on Nov 17, 2015
The bobbins are breaking while trying to load with the thread i have broken 4
Carol Sabo
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 26, 2015
Carol Sabo
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
422
Points
15 J bobbins not just 15
Troubles with the bobbin tension on the singer quantum 9960
the small flat spring on the bobbin holder under which you pull the thread is the tension setting for bobbin thread
it extremely delicate and just a partial turn of the screw that holds that spring in place has a large influence on the tension
mostly problems here are that the needle tension is insufficient and causes the problems
Confidence Quilter 7469Q how do I load the bobbin?
Are you trying to wind the bobbin or just dropping it into the bobbin case and bring up the thread?
To wind the bobbin, place the spool on the pin and secure it with the spool pin cap. Pull the thread and pull it through the thread guides. The first guide is accessed by going around it and then pulling the thread under it. Go under the adjacent guide and then wrap the thread counter-clockwise (when facing the front of the machine) under the next guide to bring the thread back to the bobbin winder. Hold the bobbin with the hole up and pull the thread through that hole. Push the bobbin winder shaft to the far left and place the bobbin on the winder pin. Push the bobbin and winder shaft to the right until it clicks. Hold the thread and start the sewing machine. It will automatically stop when the bobbin is full. Move the bobbin winder shaft and bobbin to the left and take the bobbin off. Then cut the thread to separate the bobbin from the spool thread.
To put the bobbin into the bobbin case and bring up the thread:
Make sure that the needle is in the highest position (use the handwheel). Then open the bobbin cover by pressing the release lever to the right and then lifting up the cover. Hold the bobbin with the hole up so that the bobbin turns counter-clockwise when you pull the thread. Drop the bobbin into the bobbin case. Pull the thread into the slot just to the left of the bottom center (6 o'clock on a 12-hour analog clock), of the bobbin case. Place a finger on top of the bobbin and pull the thread to the left until it stops at the slot between the 7-8 o'clock position. Now pull the thread along the groove in the needle plate to the thread cutter. Replace the clear bobbin cover. The thread should be pulled up by the needle thread without any additional effort. (If it isn't, there may be a problem with the bobbin case or race.)
Singer has the manual for the 7469Q on their site: http://www.singerco.com/support/instruction-manuals . The direct link to the manual is http://www.singerco.com/uploads/download/549_7469_efs.pdf . Winding the bobbin is on page 16; threading the bobbin at the bobbin case is on page 18. These pages have good pictures to go with the descriptions.
I hope this helps.
How do I correct excessive noise and rattling of bobbin in Singer Quantum Stylist 9960 model sewing machine?
Do NOT oil!!
You need to have the bobbin case replaced. I had mine replaced under warranty.
Pressed foot is not moving to sew
this bobbin spindle alternate postion is for loading the bobbin from a spool of thread. on older machines with a wheel the inner part of the wheel was turned to dis engage to foot end to do the same task.
Can not lower the needle to pick up bobbin thread on my Singer Stylist 7358 machine
Where the bobin is at re check the exterior of the part that spins you may have a thread stuck and keeping it in place use a flash light then replace bobbin as you depress the power controller asist the wheel this should free up the bobbin area and should run
I tried to bring the inferior thread up after put in the bobbin but the needle do not pick up and stopping me for sewing
Is the bobbin put in right? Make sure the thread is coming off the bobbin in a counter-clockwise direction. Also make sure you're leaving enough thread coming off the bobbin for the top thread to grab hold of to pull up.
2answers
1helpful
Sewing machine keeps skipping stitches
Generally, it means that the bobbin is too tight in the cavity.
1. Remove the bobbin
2. Try a drop of oil in the bobbin cavity in the machine, using a Q-TIP
3. After applying the oil, use a clean Q-TIP to remove excess oil in the cavity (may need more than one clean Q-TIP).
4. Replace bobbin.
(I'm sure you already tried differenty thread)
Hope this helps!
Top Singer Irons Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Singer Iron Expert? Answer questions, earn points and help others
