We checked the breakers and the fuses.
A lot of microwave circuits have GFI outlets at their plug-in point or nearby; sometimes the adjacent bathroom. The TV could be on the same circuit. look for an outlet with push button reset on it.
Using a multimeter to check an ac wall outlet - YouTube
? 2:31
https://www.youtube.com/watch?v=cXlVVgsp64c
May 8, 2013 - Uploaded by Bill Eaglerunner
Checking out voltage on an ac wall outlet using a digital multi meter. ... Warning: If unfamiliar with electrical ...
Could be you have a faulty microcircuit breaker on the dead circuit though a consumer unit that contains fuses wouldn't usually have any microcircuit breakers.
I have known wired fuses to seem ok but have a near-invisible break in the wire. The only way to discover this is to remove the fuse and give the wire a gentle tug with snipe-nosed pliers or forceps.
If you find the fuse blown or circuit breaker tripped, unplug everything from the circuit to which the microwave is connected (keep in mind that other outlets may be fed from the same circuit). Replace the fuse or reset the circuit breaker. If the same thing happens again, you have a problem with the outlet or other wiring on the same branch circuit. If plugging in the microwave causes the fuse to blow or circuit breaker to trip immediately, there is a short circuit in the power cord or elsewhere.
The microwave oven may be powered from a GFCI outlet or downstream of one and the GFCI may have tripped. (Removing a broken oven lamp has been known to happen.) The GFCI outlet may not be in an obvious location but first check the countertop outlets. The tripped GFCI could be in the garage or almost anywhere else! Pushing the RESET button may be all that's needed.
Next, try to set the clock. With some ovens the screen will be totally blank following a power outage - there may be nothing wrong with it. Furthermore, some ovens will not allow you perform any cooking related actions until the clock is set to a valid time.
Assuming these are not your problems, a fuse has probably blown although a dead controller is a possibility.
While you can do some repairs on your microwave, what you don't know can kill you... even on an unplugged microwave, so make sure you understand the dangers and how to reduce them before you try anything inside a microwave. If you want to do more yourself, go to the link at the top of this post.
