Question edited for clarity. 'field cycle' to fill cycle.
Do you hear water running? Water inlet valve failed.
or
Taking too long to fill. Check the strainers in the rear where the hose connects and check water flow from the hose.
Also try a power disconnect overnight to do a power reset of the control board.
If the cold water supply is slow or not entering the tub at all, the washer will stop ahead of the rinse cycle while waiting for the tub to fill. This can be caused by a clogged water inlet valve, the main water supply valve being partially closed, or low water supply pressure from the home.
Crosley Washer stops mid cycle - Repair Clinic
https://www.google.com/search?q=Crosley+Professional+Washer+washer+stopping+at+beginning+of+fill+cycle
