LG Washer Door or Lid Won't Lock - Model WM2455HW ...
www.repairclinic.com/...Washing-Machine/...-/LG-Washer-door-or-lid-...
LG washer door or lid won't lock? Use our DIY troubleshooting & videos. Then, get the parts you need fast. Return any part for 365 days.
SOURCE: DE error code
That is a door switch error problem. The door latch is not sensing the door closed. You may need to replace the door latch assembly.
SOURCE: LG Washer dryer error dE
Unplug the machine.
Plug back in (maybe 10 seconds later).
Mine had several dE messages. Unpluged, waited 10 seconds, when pluged back in, it remembered which cycle and parameters I had it on, then locked the door and continued with no problem.
SOURCE: My LG intellowasher DD WM1480
I have this problem too for my LG Intellowasher. I suspect it is because you're selecting "Rinse Hold" from the options. Try turning the power off and washing again on another setting to see if this resolves the issue.
SOURCE: DE door switch problem
I bought a switch in Portugal by €7,5 and ...nothing. I bought a drain pump €18 and still not working. I have consult one tecnical expert by phone were i bought the pices and he said tha could be the pwc board (€75). Here in Portugal they quote €25 to come and €30 per first hour...I decided and I bought a new Lg with direct drive but I stored the old Lg (6 years old, without problems, and working 2 times per week)...if you try... and it works tell me ok ? Good Luck.
SOURCE: amana front load washer error code "nd". Door is
Hello there and welcome to fixya
From what you're describing it sounds like the drain pump is blocked.
The nd error code indicates "no drain". If the unit can't drain it won't
spin. You're going to have to slide the washer out far enough to remove
the rear panel; be careful not to damage the floor. Once you get the
rear panel off you will see the pump. Be sure to have plenty of towels
& a small container to catch water. I am sending you instructions
from the service manual to remove and replace the pump. Another
possibility is the drain line is blocked or something is stuck in the
tub to pump hose.
