Water and grounds overflowing basket
SOURCE: Grounds splash from basket into carafe
In the paperwork that came with the Bunn, it said that Soft Water can be slow to move through the grounds and the filter. There was another scenario, but I don't remember it right away. If you can get a copy of the instruction manual they give a couple of suggestions and offer to provide (free of charge) a spray head that should help the situation.
SOURCE: Brewed coffee mess
You may be grinding the coffee to fine making the draining a little slower. There's something called a fast flow filter that may help also. Also, make sure that you aren't jamming the filter down to partially block the drain hole ensuring that it is freely draining out unobstructed
SOURCE: The Bunn CW Series overflows the pot. How canwe
Open the front panel, there is a set of instructions on it, you will have to make sure the board is set to program and not lock, before you adjust.
SOURCE: water fills the filter and overflows with coffee
Are you using the original Bunn pot (carafe) or a replacement ?
At the bottom of the filter basket, there's a little lever that closes off the coffee flow when you remove the coffee pot. The idea is that you can pour a cup early, before the full pot is brewed, and it won't spill coffee all over the hotplate.
The original coffee pot fits right against this little lever, but if you have a replacement that's not the right size/shape, it won't reach the lever.
If this helps, please be sure to hit the thumbs-up for me.
If not, use the "add comment" and let me know what's up, and I'll do what I can to help!
SOURCE: had about a week. if i fill with 50 ounces of
Try taking the filter out, and turn the sprayhead off the unit. Put the basket back on, and try pouring clear water through the unit. If the water runs through fine, you either have a plugged sprayhead or are using too finely ground coffee. Look at the holes in the sprayhead, and make sure that none of the holes are plugged. If the basket still overflows, try using a drill bit to make the hole in the funnel a little larger. Good luck.
