JVC AV-48WP74 48" Rear Projection HDTV-Ready Television Logo
Posted on Jul 13, 2009
My 48 inch jvc tv has a green color to it what can this be and how can i get it fixed
Anonymous
Level 1:
  • Contributor 3 Answers
  • Posted on Aug 24, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
2660
Points
20
Okay so the green color that you see on the screen is because the coolant inside of the green picture tube is gone bad (it suppose to be cristal clear but now it is brownish and that makes the green color run all over the screen.) That just happens over time and I'm guessing the picture tubes have never been serviced. Now you got two choices
1- The easiest and fastest way would be to take it to a local repair shop and have them service the coolants of your picture tubes. I'm guessing it would run you about $165 or so to get them done (the three of them red,green and blue)
2-On the other hand you can do it yourself. It is not hard at all but it does require a lot of attention.
After the picture tubes have been serviced you'll notice the big difference.
You'll actually have a much brighter and sharper picture just like when it was new.
Let me know if you decide you want to do it yourself so i can post the instructions for you.
  • Anonymous Sep 03, 2012
    JJust in case I want to do it myself please post instructions. Thanks, Bonnie.
JVC Hd56fn97 56-inch 1080p Hdila Rear Projection Tv with all blue color green
Talk to JVC as I have suggested and this is likely a known problem: loss of any color, picture upside down etc requires a upgrade to correct and I have seen about twenty sets with their name like this with this kind of problem.
Tv screen
this is your convergence amp
for cheep repair call
719 687 6997
JVC 48" AV-48P776
no se ve bien los colores jvc 48 776
Tv set 48 inches projector..[jvc]
replace 2 X convergence ICs and align. Maybe burnt resistors as well.
[email protected]
Calgary
http://calgaryconvergencerepair.weebly.com/convergence-repair-explanation.html
JVC AV-48WP74 only has green color
Have a shop look at it. you cant fix it at home. really.
Green bent line on 48 inch jvc
Check for a burnt resistor on the convergence circuit board. This is usually what happens when the green gets distorted as the green is not adjustable only through the service menu so its either a burnt resistor or a leaky capacitor. Resistor is far more likely. Let me know if you need any further information.
JVC 48WP74 HDTC rear projection
While it is true JVC tubes rarely fail, they can give trouble.
Another possible solution is bad screen / focus block......
Remove lower front grill panel and access board...Check for
smooth adjustment of RGB screen and focus.....let me know....T..
No color
You're using YPbPr (Red/Green/Blue Component) cables, right? Make sure you've got them in the right inputs and that the cables are FIRMLY attached. (Sometimes they seem attached even when there's a half-inch or so of space still)
2helpful
3answers
JVC MODEL # AV-48WP74 48 IN. BIGSCREEN TV.
I had a problem with my TV colors not lining up. One day I turned it on and the green was out of wack. I checked this message board and replaced the STK chips, bad soldering and all led to me just giving up on that and buying a whole new Convergence Board ($185). I just plugged this in and though now my Green lines up okay, my red is out of whack. Is there something I am doing wrong? Can anyone help me? Did i miss a step? Frustrated......Bruce
Jvc tv picture quality
sounds like your crt tubes...meaning Red, Green and Blue are out of alignment...or possibly 1 of the crt's is burned out.
Top JVC Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
 Grubhead
Grubhead
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
