SOURCE: Whirlpool Gs5shaxnb02 Ice maker
HI!
In my refrigrator ice is not making . My frig is about one year old side by side. All of a sudden I noticed water stop coming in the ice dispenser. Please advise me what went wrong.
Thanks
SOURCE: Continental electric ice maker CE-IE65151. The
My machine just stop making ice and now the water won't even go into the ice case
SOURCE: ice maker not working
Try swapping the wires on the dual water inlet valve. It’s on the back where the water supply comes in. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
A strainer before the inlet valve can also get stopped up restricting flow.
SOURCE: Ice maker will not make ice, water dispenser is working
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
oypyiooiyp
when mine did that i got out the air compressor and blew all of the dirty and stuff off of the moter and low and behold it worked great but be carefully I tore a blade off the fan and now it runs alittle noisey. still makes great ice now I gonna find another fan blades. you need to unscrew the back to do this.
