Long after should have moved on to Rinse, just constantly repeats short cycle [fill, empty, run for a few seconds ]. That total cycle time between 20 & 30 seconds, sometimes with 1 fill/empty, sometimes 2, they last c. 10 secs each (overlap with the fill & pump)
SOURCE: Miele Premier novo washing machine
Flashing rinse light is a drive fault. No motor action. If it's an earlier model it would be the motor brushes. Later model will be the electronic which controls the motor.
SOURCE: Miele Washer problem Novotronic Premier
Main wash light flashing is a heating fault. You either have a faulty temp sensor (NTC) or the pressure chamber has blocked and the heater element has popped.
SOURCE: Miele Novotronic.
all miele are supplied with schematics. on washers take the top off and its on top of dispenser tray. if not there remove front panel it will be there
SOURCE: Washing machine problem
my w830 is doing exactly the same thing.
I am usually pretty good at fixing these sort of things so if/when I solve it I will post back here.
I think it is a motor fault - most likely the motor brushes are worn out.
SOURCE: I have a Miele W1918 washer which has worked
I have exactly the same problem. I am currently getting around the issue by letting the machine do the washing then at the end of that cycle do a manual rinse cycle.
