Coleman Mach III Air Conditioner Logo
J
Jenny Turner Posted on Nov 07, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Brand new Coleman Mach 8 RV aircon worked yesterday but today blue on light just keeps flashing and no compressor working
David Ledd
Level 2:
New Friend:
  • Expert 21 Answers
  • Posted on Sep 12, 2016
David Ledd
Expert
Level 2:
New Friend:
Answers
21
Questions
Helped
22783
Points
122
No, most likely not a thermostat issue. Check input voltages first. If they fall within spec, then I would go that route: Coleman Mach RV Air Conditioners and Parts RV Air Conditioners Thermostats...
Bill Long
Level 3:
Guru:
  • Coleman Master 606 Answers
  • Posted on Mar 01, 2016
Bill Long
Coleman Master
Level 3:
Guru:
Answers
606
Questions
Helped
273702
Points
1197
If you Google airxcel.com, you should get some options. to get either their literature or tech support and they should be able to help you.
5 Related Answers
Anonymous
  • 540 Answers
  • Posted on Aug 28, 2008
SOURCE: coleman mach air
Time for a spring cleanning,, especially the drainnage system, filter,, front cooling coils-and the drain line! thank you-very-much!
Anonymous
  • 127 Answers
  • Posted on Jun 30, 2009
SOURCE: coleman mach air conditioner in rv tries to start
“The voltage could be low – ”
a) Check the voltage between #1 on the
overload switch and the “R” terminal of the
compressor while it is not humming. This
voltage must be 115 volts domestic USA
models or 240 volts export/overseas models.
No less than minus 10% is allowable.
b) Check the voltage from “C” or “R” of the
compressor while it is humming (trying to
start). The latter reading will probably be
lower, but it still must be 103.5 volts
minimum domestic USA or 216 volts
minimum export/overseas models.
If the first reading is above 103.5V domestic USA and
the second is under 103.5V domestic USA, there is
too much voltage drop in the lines - a situation which
must be corrected for the air conditioner to perform
safely and satisfactorily.
2. “A capacitor could be shorted, weak or open.”
Turn the power off.
Caution – There is always a chance that a capacitor is
holding a residual charge, so before touching a
terminal, discharge the capacitor as explained earlier
in this booklet.
Remove capacitors, visually examine them and test
them per instructions given in earlier section on
capacitor testing (See page 9).
If the capacitors test OK, replace them and carefully
reconnect the wires. Be sure the wires are connected
to the right terminals.
3. “Start relay contacts could be open – ” if so equipped.
Turn off all power, then check for continuity with
ohm meter between terminals 1 & 2.
4. “Compressor start winding could be open or
grounded.”
Check compressor windings per instructions. See the
section on the compressors (See page 8).
5. “Compressor could be mechanically stuck.”
This very rarely occurs and when it does, it is usually
after a lengthy shutdown. This should be considered
only after all the above possible causes have been
positively eliminated. To free a stuck compressor, use
your hermetic analyzer according to the
manufacturers instructions.
Anonymous
  • 3361 Answers
  • Posted on Jul 21, 2009
SOURCE: rv coleman roof mach 3 a/c compressor runs
Replace the thermostat.
Anonymous
  • 1515 Answers
  • Posted on May 22, 2010
SOURCE: Mach III Air Conditioner: i have a coleman mach I rv air conditioner. Last ...
Hi, its very possible the capacitor is open or shorted. Look it over to see if it is leaking oil or swollen or even deformed. When installing a new condenser fan motor, they should sell you a new run cap with it. Its probably a 5 uf 370 volt cap and you can have it checked to see if its putting out the right amount of micro farads. If it shows any of the signs I have said, the cap is bad and you will need a new one. Does the motor spin free? If you have a meter, a digital is best, you can check to see if the motor is open or shorted to ground. Set the meter on continuity, and check each lead to ground. If it is open, your meter will show no reading. If shorted to grd, you will have a reading or a beep if your meter has that option on it. This is how you will know. If it would be best for you to take off the run cap and take it in, they can check it for you where you bought the motor. Its not unusual to loose a motor in a year as they work hard in the heat. I have seen them last for years and for just a couple of months. Keep me posted.
Best of luck to you,
Shastalaker7
mike cooper
  • 884 Answers
  • Posted on Apr 23, 2012
SOURCE: coleman mach rv roof ac, the fan comes on but the compressor doesn't, i've replaced all capacitors and stll is not comming on, how do i check voltage to the compressor to maske sure i have pow
At the compressor connectors you have a live and a neutral phase. The live usually goes to a ptc relay starting mechanism which you can test with a meter. If you can disconnect the relay and check the windings of the compressor from one pin to the other two it will tell you if the compressor is open circuit. It is more often than not an overload fault.
2answers
2answers
Coleman mach 6759C707 quit on us, only the fan is running. What do i need to replace? The compressor? WHat part number?
my coleman 7330 fan only runs when ac unit is on and then sometimes shuts off and then restarts
Coleman Roof air on Rv starts to cool the pops the breaker any ideas?
Yes, the capacitor to the compressor or the compressor its self have gone bad...try changing the cap first....then if that don't work its big bucks...
heatman101
2helpful
Today the blower motor started running slowly,approx.half normal speed, both high and low setting,on our Coleman Mach 3 ac unit.I believe it is orig.in our '87 Hoilday Rambler.Any ideas would be much...
COLEMAN R.V. AIR CONDITIONER SERVICE AND REPAIR QUESTIONS
COLEMAN R.V. PRODUCTS
GO TO rvcomfort.com
Click on RVP (RV PRODUCTS)
Click on type of AC, if you can’t find the information you want there,
then click on contact us on the Green Bar.
You can get Service Support or Email address and Phone numbers.
1helpful
Model coleman mach 8333c8714 serie 8000 my a/c start for 2-3 minutes and than the a/c shut down but the fan still working!! after a few minutes , it want to start again but dont seem to be able to. you can...
GO TO rvcomfort.com
Shastalaker7
Coleman mach 3 rv roof mount ac
You will need 12 vdc (battery or converter) for controls to work, and 115 VAC (hydro) for fan & compressor to work. With your fan obviously working, that tells me you have both already but compressor may not be kicking in. Do you hear a "moaning" sound or see lights dim when switched to cool?
1helpful
2answers
Compressor tries to turn on but cant.
Try changing out the start up and run capacitors for the compressor.
Top Coleman Heating & Cooling Experts
Paul Carew
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
