FRANK WATERMAN AT SIERRA BIOMED. [email protected]
SOURCE: Nikon Optiphot-2
You can purchase a variable power supply that will light this lamp and control its intensity if you determine that the power supply in the microscope is bad. This may be the easiest way to fix the problem. Parts for many older microscopes are no longer available and this is a common way to repair the microscope. It's also a common modification made to many laboratory instruments for research purposes. Carefully check the lampsocket as well. It's common for them to fail and replacement is the only cure. The lamp socket is not expensive.
SOURCE: I own a MRJ-03 Premiere microscope with the a bad
I have the same problem and can't find parts anywhere. Premiere Microscopes doesn't answer their phone or return calls and their customer service email keeps rejecting everything I send. Please let me know too if there are parts available for this microscope.
[email protected]
