How do you get started John Deere XL176 38 to run again
I replaced battery and drive belt for blades now he wont start not even jump start or battery charger before I got new one.... What Im I overlooking????
You have indicated a bad battery. There is enough charge in the battery to start and run buy not enough when you engage the blades. Check the battery by load testing it and checking with a multi-meter.
Some mowers have a mowing reverse safety switch. That safety will kill the mower if you try to reverse with the deck engaged. Some mowers even have an override button that has to be held while backing up. As for the battery thing, no matter how much you charge a bad battery you will not get it to start a mower if it has a bad cell or two. I would use a multimeter to check battery voltage, but the end result would still be the same, replace the battery.
