Hope you are using the buttons on the tv.
press the source button repeatedly to select the desired input. every time you press the source will change HDM1, HDMI,2 and so on
If it didn't t work try the following
Press the source button and then press volume up or down or channel up or down to select the source. and then press ok , if ok button is not there the do not do anything it will automatically set the selected input
www.electro-medical.blogspot.com
SOURCE: No display
Well I just joined in the world of broken Samsung's. Died Feb. 1st. I had three month additional warranty, but of course it died the day after. Same problem, no video, just audio.
However if you call 1-800-522-7341. This is the number for Executive Customer Relations. They extended my warranty and contacted the repair center for me. Probably won't be fixed by Superbowl Sunday though. I expressed my disbelief that after 15 months a 2400 set can die. I have to call back on Monday for additional help.
SOURCE: please help me
I bought one too! It failed in 6mos. I sent the $ and returned the bad one for another of the same "no choice". Now they suddenly "lost" my replacement. Fix that, haha. Do you have a fax# for RCA?
Please help me.
SOURCE: hdmi cable to Samsung TV. Selected source and the
Try pressing the Picture Size or P-Size button. Your remote will have that button.
SOURCE: I need to change the source on my tv to HDMI without my remote
Not sure if yours is the same but Philips codes work with Skyworth and if you hit the TV/AV button on the side of the TV and the table of options should come up. And then with the channel +or- go up and down till you are on HDM1 or where ever you want and then touch the TV/AV again when you are there.
