I have a Panasonic CQ - vd7500u. I need the connection from the back Tony had the radio the 7-inch screen can you give me a price for the items
Look here
http://www.manualsonline.com/
SOURCE: removal of sprocket and gears from rear tire for replacement
A special sprocket removal tool is required usually only $20 to $30 bucks at a decent bike shop.
SOURCE: Adjust front suspension on a Mongoose XR-75
i dont think you can......because these bikes are made for confort at a cheap price..........
higher value bikes can be adjusted....they have special shocks and you can adjust on either soft or stiff ride.....
SOURCE: front suspension to soft on mongoose xr-75
The front forks aren't adjustable, as you probably figured out. You can, however, get harder springs if the springs can be accessed at the top of the fork tube. If not, do what I did on my mountain bike. I bought a better pair of adjustable forks that I found on eBay. It will take a bit of investigation on your part regarding the dimensions of the forks, so you get the correct length and width where the forks fit onto the frame (and the overall desired fork length), but you'll be a lot happier with adjustables.
SOURCE: New Mongoose 700c Men's Paver bike: Mongoose 700
Local bike shop determined that both wheels were defective. I took the junk back to Walmart and got a refund... PROBLEM SOLVED!!
SOURCE: Mongoose Handlebar adjustment
where the bars slide into forks there should be a allen nut on the top undo this slightly and adjust bar height then tighten up allen nut
