SOURCE: LG Refrigerator model LFX25950SB
it means that the motor fan inside freezer the sends air to the ice maker is not communicating with mother board you have no ice right then you need either the motor fan or main board if you dont know howto trouble shoot you need a tech to come out
SOURCE: What does message: Er FF mean?
That means the freezer fan is blocked, you need to order a new High voltage board, the ice has built up enough from not defrosting that it is interfering with the operation of the evaporator fan.
SOURCE: Freezer compartment is OK, But refrigerator is
sounds like your thermostat may be bad . the thermostat senses the tempreture in the fresh food section and turns the ref. on and off as needed . do it yourself roughly 39-89 dollars if u hire a proffesional around 95.00- 165.oo depending on were u live and who u use.hope this helps
SOURCE: error message on the display panel that says ER dH
ER dh means you have defrost issue that needs to be addressed asap. The evaporator has frosted up so badly that the circulating cold air cannot get to the refrigerator. You would need to get inside the freezer back panel and remove it to access into the evaporator coil area. Test the defrost circuits to see if the defrost terminator is broken. If it is, replace it and melt the ice build up as well.
Good luck
