SOURCE: iPhone does not get reset
put the phone in DFU mode.
hold the power and home buttons for 10secs then release the power button only leaving the home button pressed note u must be connected to itunes via usb and u will see a rec option ,press shit and clikc restore select the 152 mb 1.1.1 update ipsw file and the i phone will restore.
SOURCE: iphone only see apple logo and itunes logo in a dark screen after
If it got wet, you can bring it to any Apple Store. Nine times out of ten they will replace it for $150 to $200 dollars. Unless they determine it is a manufacturers defect and you are still under warranty, then you want have to pay anything. they will usually just replace it for you.
Otherwise, you may have to pay up to $200 for a replacement.
Hope this helps...Let me know...
enov8
SOURCE: Beginning screen is set on Emergency call mode!!!
u need jailbreak and unlock iphone read this
http://www.crunchgear.com/2009/01/01/how-to-unlock-your-3g-iphone/
,or google unlock 3g iphone
SOURCE: iPhone not charging, not recognized
You need to restore whit the last version of iTUNES and an ofiial firmware. Then apply jailbreak.
SOURCE: My iphone got stucked on the apple logo
here is a small tutorial that my help you....good luck I hope this helps please don't forget to rate
http://www.youtube.com/watch?v=u4xLvpazV24
Unlock:
Plug it into iTunes with it at the unlock screen. Somewhere it should say "Unlock your iPhone" or something like that in iTunes. Click it. Otherwise do a restore by going to the screen where it shows how much memory you have used up in iTunes and click restore.
Download the latest iTunes to your computer and reset the iPhone. Then re-sync it.
Reset
To reset iPhone, press and hold the Sleep/Wake button and the Home button at the same time for at least 10 seconds. During this time, a red "power off" slider may appear and the screen may go black, but do not release Sleep/Wake and Home buttons until the Apple logo appears.
If iPhone won't turn on, or the display freezes or doesn't respond
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays! Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Unlock:
Reset
More resets:
Try This:
1. Remove Sim Card
3. Replace Sim Card
Also, Try this:
2.) Start up iTunes
or:
Reset
More resets:
Try This:
1. Remove Sim Card
3. Replace Sim Card
Also, Try this:
2.) Start up iTunes
Reset
More resets:
Try This:
1. Remove Sim Card
3. Replace Sim Card
Also, Try this:
2.) Start up iTunes
Thanks, Joe
