The main PCB has failed and will need to be replaced. It's hard with out a model no. But I can give you a rough idea what your up for. *the attached videos & links most likely aren't your machine and the actual part you need this is just to give you a idea.
Hello Welcome to FixYa here is the answer your searching for..Press and hold the "End of Cycle Signal" button for approximately three seconds until the "Control Locked" indicator light shuts off. The control panel is now unlocked.
If this was helpful please rate me Thanks :)
1:hold the resume botton 2:while pressing resume botton press start botton 3:while holding power botton press resume botton 6 time after that leave start botton your ip4840 is on service mode. 4:please remember one thing there is no service tool yet on internet for ip4840.so please dont waste your time just throw the printer or send it back if warentee still valid if not them buy an other one.
TO RESET THE MACINE PRESS THE ORANGE BOTTON (C),PRESS THE BOTTON UNDER THE AUTO DENSITY LIGHT,RETURN TO THE FIRST ORANGE BOTTON THEN THE AUTO DENSITY BOTTON, YOU HAVE TO BE FAST WHEN PRESSING THE BOTTONS, ALL THE LIGHT ON THE DISPLAY WILL GO OFF THEN PRESS 14 AND PRESS THE GREEN PRINT BOTTON,THE MACHINE WILL RESET AND START TO WORK, BUT IF THE PROBLEM COUNTNUE CHANGE THE FUSER UNIT.
First of all check whether there is sufficient battery charge to run the laptop. If not you have to charge the battery so that you can start the laptop.
did you try to sync it? Thier is a red botton on the back of the controller, also one on the middle of the wii were the sd card goes in press that and press or hold the red botton on the controller.
go in contact wit EG customer service or the store u bought the washing machine and tell them ur problem,,, make sure u have power on ur power outlet and it is switched on,,,,,
boot your computer in safe mode and in display properties>Screensaver>Power tab>Advance>
"When i press the power botton on my computer " select "do nothing" and " when i press the sleep botton on my computer " select "do nothing"......
then press ok and apply then restart your computer in normal mode it will work
