There are only picture instructions but from what it implies...
Reset the Unit
- remove all the batteries from the bell
- ensure the battery in the doorbell unit is working and remove the back cover
- replace the batteries in the bell unit
- within 30 seconds of the bell unit sounding the bell, press the melody changer button on the back of the door bell unit once
Pair the Unit
- wait at least a minute after reset
- within 30 seconds of the bell unit sounding the bell, press the door bell button
their helpline is: 0845 2301231
Go to manufacturer web site for manual download.
SOURCE: Trying to reset the code for my DESA wireless
It would appear that there are pins in both the ringer and door button and you have to change them so they match. To remove the door button, slide the case straight up slightly (maybe 1/8 inch). Pry the top of the case away from its base and slide down to remove the entire button assembly. The pins are inside, next to the battery. 5/6/7 seems to be the default, so any other combination of three pins should solve your neighborhood conflict. (Don't use pin 8. That one changes the ring from a two-tone chime to a 16-note sequence.)
SOURCE: how do I change the battery in the wireless doorbell button?
in the wireless doorbell button, you can plug out the old battery, and then plug into the new one, be careful, new one should be the same type as the old one, try it , good luck!
There are only picture instructions but from what it implies:
- remove all the batteries from the bell unit for at least 1 minute
that should pair the two
- wait 1 minute before re-trying, removing the batteries from the bell unit first
hope that helps
Neither answers on here worked for me. Paired mine by looking it up on you tube (instructions for Blyss doorbells come up as Byron).
Put batteries in the bell sounder unit, it should chime when you put the last one in.
Take a pen and depress the black button (marked L) on the back of the sounder unit until the sounder unit chimes, then remove the pen.
press (but don't hold) the black button again once. The sounder should chime. if it does then it should be paired. check by pushing the push on the other unit.
This does not work,
It worked for me. took a couple of tries. Thanks
