Model LGT2654 with only 60 hrs on it but it is 6 years old. You can start the mower but the blades will be running.
SOURCE: Knocking in mower deck or belt clutch when engaging blades, motor bogs / slows down
YOU MAY HAVE A BENT BLADE OR EXESSEIVE BUILD UP UNDER THE DECK
SOURCE: Craftsman riding mower blades will not engage
maybe the safty switch under seat might be starting to go out if that switch doesn't work the blades wont come on at all for safety
SOURCE: prob with PTO on craftsman mower 917.273372
There is a idler pivot plate on the mower that must be cleaned and lubricated regularly, from the left side of the mower deck if you look in the middle of the mower deck while someone engages the mower(with the engine off) you will see the pulley try and move,there is a 3/8 bolt that comes up through a bushing that this pivots on, soak that area with wd-40 and see if that improves the movement. Be sure not to get any wd-40 on the belt or pulleys. Always try and keep that area clean and lubed.
SOURCE: Husqvarna Mdl YTH2448 Riding Mower - Electric PTO Not Working
It sounds like your charge system is not working. If you jump the battery the engine will run with a weak battery but the pto clutch needs a strong battery to stay engaged.Try this to test it,after you jump it leav the jumper cables hooked up and try to engage the blade clutch,if it runs it is either a battery that wont take a charge or a charge system not working. If you put a volt meter on the battery while the engine is running and the voltage is 13 volts the charge system is working and the battery is bad.
