There is a sleep function and a power off function. Hold the power button down for a longer time and see if it gives you power off.There is a sleep function and a power off function. Hold the power button down for a longer time and see if it gives you power off.
You can't post conmments that contain an email address.
Press and holding down the power button for 20 seconds or more. Then turn the device back on by hitting the power button again. If this doesn't work the first time, you can try holding the button down for 30 seconds or more. Most of the time, this will be all you have to do to make the Kindle Fire work again.Oct. 11, 2014
May 26, 2020 - Perform a soft reset. A soft reset resolves many common issues without affecting any data on the device. Press and hold the Power button for 40 seconds, then release. The charge indicator light should turn on after several seconds, and then the Kindle Fire should reboot.
Fix an Amazon Fire that Won't Start. Hold Power Button. Ensure that you are holding down the "Power" button for at least 5 seconds to power it on normally. Charge Using AC Adapter. Ensure that the Amazon Fire has a charged battery. Hold "Volume Down" While Powering On. Restore Latest Software.
Patricia, Using the power switch, you can forcibly reset your Kindle device. This reset will shut down the Kindle without accessing the shutdown command from within the Kindle's operating system, a particularly useful tool when dealing with a frozen Kindle. To initiate a hard shutdown, Kindle disconnect from its charger, slide and hold the power switch for about 20 seconds. This will force the Kindle to shut down, now it can be restarted normally.
Check links below for charging problems. "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info." Reset Kindle Fire When it Won Turn on or Charge
Press and hold the power button for fifteen seconds or so, ignoring the "Shut down?" prompt, until it turns off. Release the button, then press and hold it for a second or so until it begins to reboot.
This is usually a sign of either a failing charger or Kindle, let's try to hard reset the Kindle. Step 1: Press and hold the power button for 60 seconds Step 2: Plug the Kindle into the changer, press and hold the power for 30 seconds Step 3: Let charge for 12 hours Step 4: Turn on and use the Kindle, if it shuts down before 6 to 8 hours of use, contact Amazon for a replacement.
If it shuts down before 6 to 8 hours of use, contact Amazon for a replacement.
It is possible that your Kindle Fire's battery has died. If you noticed
the battery life diminishing before it wouldn't turn on at all this may
be the case. Here is a site that has replacement batteries for the
Kindle Fire: 3555A2L Battery for Amazon Kindle Fire D01400
Make sure that the kindle is fully charged. Plug your kindle into the wall charger, a yellow light will light up. When the yellow light turns green, your kindle is fully charged. Then try turning on your device. If the device still does not turn on, hold the power switch for 15 seconds, this will reboot the device.
