Ford 8N Tractor Logo
P
Peter Titanic Posted on Oct 10, 2015
Tractor won't start. Tried a new battery...lights came on but nothing...won't even turn over.
Had it going a couple of days ago...let it run. All okay then...today nothing.
5 Related Answers
Kenneth Clements
  • 110 Answers
  • Posted on Nov 22, 2008
SOURCE: ford focus 53 plate wont start
may have problem with selonoid on top of starter jamming give it a tap with hammer then try
Anonymous
  • 6 Answers
  • Posted on Nov 26, 2008
SOURCE: 2004 Ford explorer will not start
Sounds like connections or cables. They may appear to look good but if they are aftermarket terminal ends they get corrosion under the bolt down clamp that holds the wires in. If they are factory cables that are molded on to the ends of the wires the same thing can happen. The easiest and cheapest thing to try is to put aftermarket terminal ends on the cables. Make sure you wirebrush the ends of the cables after you strip them and tighten them evenly and securely. Also clean the battery side thoroughly. If this doesn't work check the starter relay. Its the first place the red cable bolts to after the battery. Check the connections and try putting a jumper wire between the battery positive cable and the small terminal marked with an "S". One of these solutions should take care of this.
Anonymous
  • 398 Answers
  • Posted on Mar 27, 2009
SOURCE: 1987 F150 302 ci. EFI, Automatic,
try over riding the starter relay on the fender ,it has one there right?. dont go to a mechanic yet. the engine aint seized. if it doesnt have this relay then i would get the alternator tested. if you want to test it yourself it can be costly for the right equip. autozone usually tests for free. i dont know were you live so if theres not an autozone. let me know if you cant get it tested.
Anonymous
  • 1036 Answers
  • Posted on Aug 16, 2009
SOURCE: 2006 Ford F-350 6.0 power stroke will not start
This really is the sign of a dying battery - one that may not be getting any charge to replace it. I would disconnect the +ve lead and put battery on charge for at least 24hrs (with an intelligent charger). Then check Alternator for correct output when running. Also check for current drain when turned off. A high drain may indicate a blown diode in the alternator - the rectifier block is usually replacable without scrapping the whole unit.
Sean80000
Sean Piquet
  • 1867 Answers
  • Posted on Nov 30, 2009
SOURCE: 87 f250 drained brand new battery
I would first have the alternator checked by an auto electrician to ensure it is working correctly and is providing the correct volume of current. It may be faulty and when driving you will be drawing battery power instead of power from the alternator to run the electrics. This will drain the battery.
Alternators do not last forever and if you are still running the original unit it is likely to be on it's last legs and you will need a replacement unit.
I have a JD Tractor 150 LT, It was running a few days ago and I've just tried to start it and I turn the key and nothing. the lights don't light up, nothing. I tried jumping it but still nothing.
Check the wires and make sure they are tight. You may need to try to charge the battery for a couple of hours, if it does not charge it may need a new one.
New battery In mercedes no power
I'm not a car mechanic, but, it sounds like you might want to check the fuse to the ignition switch, and, if that fails, it might be a problem with the Start Safety Switch on the transmission. Good luck.
Test starter switch tea20 fergie tractor
Have you checked all of the main fuses ?
96 GMC Yukon won't turn over
Thats what i would try and if that dont help, maybe check the connections at the starter.
2answers
Truck is draining charge and not charging battiers
I just went thru same thing with my 2003 f-350 diesel. I hooked up my horse Trailor and drove to Von's parked went in came back out and truck was dead. I tried to jump it didn't work. Then over next two hours two tow truck Drivers hooked up to both batteries full power charge direct to my truck and would not start.
End story required two new batteries alternator and cilanoid discussed above. In other post. Also contributing to the cause was really badly coroded cables they looked good at the connection point but wher discovered to be coroded inside the tubing just above the end connections so bow it has all been replaced and I have had no trouble since. Hope this helps. Tanya
Nikon Coolpix won't charge no matter what
The internal battery, which is kept charged by the removable battery, has probably run down. Take it to a repair facility.
3 days ago, i went to work no problem,had to move it after 6-7 hrs of time, would not turn on 2 try's, started like normal on 3rd. 2 days ago i drove it locally a couple of times, no problems. today...
I ran into the problem and it was corrosion on the battery terminals. on the inside against the battery. also check the the terminals for good connection.
Stay warm
3answers
Car won"t start..acts like the battery is dead .
possibly the alternator. or even a bad connection on one of the wires
Top Ford Toys Experts
Kardoc
Paul Katynski
Paul Katynski
Are you a Ford Toy Expert? Answer questions, earn points and help others
