Question about Canon Office Equipment & Supplies
CANON IR Advance Error code E000880-0004 appear when machine is on and not being operated
    New Friend:
  • 34 Answers
Would need more information about your problem.
Posted on Feb 20, 2019
C5030 error code. E000880-0003
Posted on Sep 20, 2018
    Master:
  • Canon Master
  • 906 Answers
Model of the machine?
Posted on May 14, 2018
6ya staff
SOURCE:
Sunil Rathod
  • 199 Answers
SOURCE: canon ir 2200 Error code E000064-0000
E064 The presence of a high-voltage error is communicated by the composite power supply PCB. (The output for primary charging, developing, or transfer
has deviated from a specific level of voltage.)
Main cause The contact has poor connection. The wiring is faulty. The composite power supply PCB is faulty. The DC controller PCB is faulty.
Action
1. Contact
Is any of the contacts of the primary charging roller, developing assembly, or transfer charging roller soiled? Or, is there poor contact?
YES: Clean the contact, and set it once again.
2. Wiring
Is the wiring between the contacts for the following normal: DC controller
PCB (J301), composite power supply PCB (J136), primary charging roller, developing assembly, transfer charging roller?
a. DC controller PCB (J301) <-> composite power supply PCB (J136)
b. composite power supply PCB (J130-7) <-> primary charging roller contact
c. composite power supply PCB (J130-1) <-> developing assembly contact
d. composite power supply PCB (FT133) <-> transfer roller contact
NO: Correct the connection.
3. Composite power supply PCB, DC controller PCB
Try replacing the composite power supply PCB. Is the problem corrected?
YES: Yes.
NO: Replace the DC controller PCB.
Posted on Feb 26, 2009
Anonymous
SOURCE: Canon IR C3200 Error Code E000020-03C0?
plz tell me reason of e602 code in canon ir c3200
Posted on Nov 20, 2009
Cogz
Chris Coughlin
  • 1326 Answers
SOURCE: Error code : E 604 of Canon IR 400
It means that you are having a problem with the hard drive boot up program... You will need to replace the hard drive.
Posted on Mar 02, 2010
Anonymous
SOURCE: Error code E000020 - 0081 in ir C3170 PCL5c
Posted on Jun 04, 2010
jaheedn_7445
SOURCE: Canon IR 400
i have canon ir405 cpier it dispays error code E243 please help me sir
Posted on Jan 27, 2011
E000001-0002
take out the guess work and tell me what make and model. thanks
Nov 30, 2014 | Office Equipment & Supplies
How do I fix Canon Error code E000732-0001?
Hi
You didn't mention your specific type but you can find a lot of printer error codes here:
Error Codes Canon iR Advance 4025 Code E732 0001
for many makes and models. I used the iR Advanced to get the following:
"Code:- E732-0001
Description:- Reader communication error, Communication error.
Remedy:- 1. Check the connection of the Connector with the Reader. 2. Check the power of the Reader (check if the initialization operation is executed at startup). 3. Replace the Reader Controller PCB and the Main Controller PCB."
On this page though you can change the make, model number and code by using the 3 drop down menus at the top of the page, so you can select your specific model. Another useful feature is the ability to be able to download a pdf format service manual for the machine you are looking at by clicking on the link just above the error table.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Nov 29, 2014 | Canon Office Equipment & Supplies
CAnon xerox Machine IR 2318 L Error code : E 000007-0000
My canon ir 2318L shows error**E000007-0000 how can i solve this problem
Feb 28, 2011 | Office Equipment & Supplies
I have cannon3300 But when I Switch on machine an erron appear E00002-0000 That is why machine is not operating well
Please refer the link
http://www.yoreparo.com/foros/reparacion_de_fotocopiadoras/error-canon-ir-3300-e00002-0000-t433151.html
Jan 22, 2011 | Canon imageRUNNER 3300 All-In-One Laser...
Our Canon Image Runner 330S shows error message E014....
is there an error code appear on panel display?
if there a error appear try to reset you may press * key,press 2&8 simultaneously, the select copier then select fuction then clear then error then ok then turn off& on
Jan 04, 2010 | Canon imageRUNNER 400S Copier
Ir3100 : E00070-003 error code
canon ir 3100 error code E00070-003
Oct 23, 2009 | Canon imageRUNNER C3200 Copier
Canon ir 2016 copier on display says ( Download Standby) thanks
We have a Canon IR 2016 J and in a beginning in the dispaly appears the message "Download Stanby" then after we replaced the PCB board appeared the message "System Error E354" what should we do to solve this problem, and if it is possible to send us the Service Manual with error codes for Canon IR 2016
Apr 18, 2008 | Panasonic KX-FB421 Plain Paper Film Fax
1,867 people viewed this question
Clive
Clive
old marine
old marine
Ekse
