SOURCE: won't switch on
You reports that you've changed the T'Con board. Where is the T'Con board to a Plasma TV? There is no such board to any plasmas. Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. You can also click the [Home] tab to see the latest updates. It will make search easy. There are more than 1350 posts to different brand TVs now. Pull up older posts there or make a search by typing in the brand name of the device in the "Search Box", at the top right of the display window
It could be either or. More then likely it is your mother board, which is the brains of your t.v.
Testimonial: "Thanks for the help .the faultis not on the mainboard ,it is the fuse on the t-con board was blowm. So l replace it. The tv is ok & already delivered.thanks ."
ottermusk...TCON connection interface are delicate this may cause the flashing . from.your statement for it to flash the voltage from the power inverter seems unstable...check it.....here the power inverter seems not to power up the backlight.....the led power light should blink 8x then back light turns on...u seem not to have video problem cos of the blue flash i advice you go to the power inverter stabilize it n ensure backlight is up cos its the backlight that's flashing n its powered by inverter. easier way replace power inverter
