Can you provide a number? Please the model number is important
Appliance 911 Sea Breeze
Uline CO2175FB-00
okay usually when you have everything getting hot you've got something wrong with the compressor it's possible the start relay and overload on the side of the compressor has failed can you feel the top of the compressor is it warm or very hot and you can't keep your hand on top? if we can get the compressor running correctly I believe the error code will go away
SOURCE: LG refrigerator lrsc26944tt error code ER FF
I'm no major appliance repairman. However, after reading several posts, I investigated the issue further since I received an ER FF on the front panel. I have a LFX25960SW refrigerator. I pulled the top and bottom baskets out, and was able to take the back panel out from inside. There was a solid block of ice built up around both fans and wires. I took a blow dryer and gradually melted the ice around the fans and wires. Then, as I was able, I pulled the remaining ice chunks off of the wires. I put the thing back together and it cleared the message. My wife says no more LG appliances for us. :)
DAS
SOURCE: whirlpool (er6ahkypqoo) refrigerator temperature
the rtc contactor overload on the compressor body is not holding in anymore and is short cycling the compressor you will need to access the compressor in the rear of the unit,remove the spring clip that holds the overload rtc and run capacitor on the compressor body,then unplug this from the compressor side body and replace it,then reverse the procedure
SOURCE: Runs and cools to desired temperature for 2-30
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
