KitchenAid KSM150PS Artisan Series Stand Mixer Logo
M
Michael Janea Posted on Oct 05, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What is the rpm of artisan 300watts - KitchenAid KSM150PS Artisan Series Stand Mixer
Ross Keen
Level 3:
  • KitchenAid Master 1,365 Answers
  • Posted on Oct 06, 2015
Ross Keen
KitchenAid Master
Level 3:
Answers
1365
Questions
0
Helped
582938
Points
2445
On low speed roughly 1 rotation of the planetary per second. On high speed it should be the maximum speed that motor can run at, too fast to count that's for sure.
1helpful
Motor not turning on
Get a copy of the Repair Part List for your model at Kitchenaid.com
Download a Copy of the Kitchenaid Service manual.
http://www.kitchenaidparts.be/centers/servicemanual/mixer.pdf
Make sure that the Motor Brushes are not worn out and making good contact with the Motor.
Adjust the mixer speeds (if necessary):
Remove the screw holding the End Cover and locate the three screws from the Control Plate.
All three (2 top left and right, and 1 bottom) must be adjusted.
1. Loosen the lock nuts enough & Turn the 2 top screws clockwise until they cannot be turned
anymore. Leave the bottom screw alone for now.
2. Use a dab of white paint or paper whiteout to mark the positions of the Phillips screws.
3. Plug in your mixer and Set the speed selector to "Stir".
4. Turn each top screw One full turn couterclockwise (alternating between Left and Right)
Keep making one full turn at the time (for both left and right) until the motor starts running.
5. Put your hand near the Agitator shaft and allow it to brush your finger slightly. Use your
watch or clock and start counting the number of times the shaft touches your finger in
60 seconds. The correct count should be 60 RPM (Rounds Per Minute). If it is less
or more than 60, give each screw 1/4 turn counterclockwise or clockwise and start counting
again. Now tighten both lock nuts.
6. Set the speed selector to "6" and turn the bottom screw either clockwise or counterclockwise
to achieve a speed of 180 RPM.
For your reference, the planetary RPM's for the 5-qt. tilt-head Artisan Stand Mixer are as follows:
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
Mixer has lost all speeds, only works when moving the lever back and forth. The mixer is about 9 years old.
Adjust the mixer speeds:
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
4helpful
Kitchenaid speed controller (don,t work
You need to adjust the mixer speeds.
Obtain a copy of the KSM150PS Repair Part List from Kitchenaid.com.
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
1helpful
I was grinding some meat and my mixer got very hot. I let it cool down and now it only operates at one speed.
I am not sure what has happened to your mixer but, select
different speeds from Stir to 10. If it runs OK, then there is
nothing to worry about, otherwise do the following to re-adjust the mixer's speeds:
Get a copy of the Repair Part List of your model from Kitchenaid.com
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
3helpful
The mixer goes real fast on all the settings. Whats wrong?
The K45SS is very similar to the 5-qt. tilt-head Artisan Stand Mixer.
You need to adjust the mixer speeds. Obtain a copy of the K45SS Repair Part List from Kitchenaid.com. Remove the screw holding the End Cover and locate the three screws from the Control Plate. All three (2 top left and right, and 1 bottom) must
be adjusted. 1. Loosen the lock nuts enough & Turn the 2 top screws clockwise until they cannot be turned anymore. Leave the bottom screw alone for now.
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
Speeds don't increase after 6
You need to adjust the mixer speeds. Obtain a copy of the K45SS Repair Part List from Kitchenaid.com. Remove the screw holding the End Cover and locate the three screws from the Control Plate. All three (2 top left and right, and 1 bottom) must all be adjusted. 1. Loosen the lock nuts enough & Turn the 2 top screws clockwise until they cannot be turned
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
1helpful
My wife's Kitchen Aid Artisan 325W mixer has no high end speed. I tried a new set of brushes with no change. Then starting on speed 1 to 2 and from 2 to 4 you get a nice speed increase the speed the...
You need to adjust the mixer speeds. Obtain a copy of the KSM150 Repair Part List from Kitchenaid.com. Remove the screw holding the End Cover and locate the three screws from the Control Plate. All three (2 top left and right, and 1 bottom) must all be adjusted. 1. Loosen the lock nuts enough & Turn the 2 top screws clockwise until they cannot be turned
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
1helpful
I could not regulate the speed as usual. Hubby removed the phase control board and a new one was purchased #9706595. It arrived and was installed and now the mixer won't even turn on. HELP please.
The K5SS is very similar to the 5-QT Artisan KSM150.
You need to adjust the mixer speeds. Obtain a copy of the K5SS Repair Part List from Kitchenaid.com. Remove the screw holding the End Cover and locate the three screws from the Control Plate. All three (2 top left and right, and 1 bottom) must all be adjusted. 1. Loosen the lock nuts enough & Turn the 2 top screws clockwise until they cannot be turned
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
2helpful
Kitchenaid Artisan KSM150 Stir problem - Stir speed is the same as setting 2, but all others (4, 6, 8, 10) work fine. Tried adjusting the control board but "stir" and "2" still spin...
You are not adjusting the screws correctly. All three screws (2 top left and right, and 1 bottom)
must all be adjusted. Here is how:
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
The KSM150PS 325W mixer does nothing until speed control is moved up to position 8 or 10. Then when repositioned back down to say 6 it may run for a moment but then stops. It might just click on position...
You need to adjust the mixer speeds. Obtain a copy of the KSM150PS Repair Part List from Kitchenaid.com. Remove the screw holding the End Cover and locate the three screws from the Control Plate. All three (2 top left and right, and 1 bottom) must all be adjusted. 1. Loosen the lock nuts enough & Turn the 2 top screws clockwise until they cannot be turned
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
Top KitchenAid Food Mixers Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
