Not sure what model you have or the age, but it could be the door gasket. It could also be the door closure at the bottom of the hinge side being worn down and not closing the door all the way. These normally last about 15 years.
You have a side by side or a undermounted freezer? I am having the same problem with mine. Take a look into the bottom of the freezer, there is probably ice building up on the bottom of it under the bottom self or basket. It seems if the refrigerator door is opened frequently and it is moderately or very humid in your home the water vapour condences inside the freezer. There is probably a condensation tray somewhere that is overflowing into the freezer compartment. Once the ice build up on the bottom gets to a certain point the water then starts to run out the front of the fridge onto the floor. Remove the ice from the bottom of the fridge and empty the condensation tray. You may have to continually do this during humid periods. For me that is about 6 months of the year every 3 to 4 days. It's a pain but what are you going to do.
Sounds like your door seals are not seating causing moisture to migrate past the seal and condense and freeze. Check to see if this is true will small strips of paper. If you place the strip in the door and pull, you should have some resistance. If you pull and it moves freely, your door seal needs to be realigned or replaced
Clean the coil inside the rear access panel behind the unit with a spray air duster and check for this problem.
I just opened up the back of my Frigidaire Side by Side counter depth to find the drain hose was bent and collapsed coming right out of the bottom of the freezer and the pan was dry as a bone. It doesn't look like my drain hose has ever drained a drop of water. The freezer bottom is full of ice And the rust and chipping paint under the bottom of the freezer door along with the mysterious puddles of water every morning means the drain system definetely never worked. Frigidaire should be responsible for this. This, along with the ice maker rebuild I had to do,... after ice was spilling all through the fridge. I actually had warrantty left on that one and called customer support in India to find out I could make the repair myself. Yep I had to do it. Frigidaire you failed.
check this website repairclinic.com they are talking about a clogged drain plug for the defrost cycle. seems we have exactly the same situation. see if this helps
sounds like a defrost problem maytag has problems with the defrost thermostat use a hair dryer to melt the ice on the coils and see if the defrost thermostat is swelled up on the edge
remove back panel inside freezer. you will see drain tray at bottom with a drain hole in the middle - this is blocked usually with ice. melt off with a hairdryer and follow up with hot water till water flows away freely
Sounds llik a defrost heater is open if you have a VOM you can test it for continuity Its probably behind a panel in the rear bottom of the refrilgerator Should have a pan under there to
Sounds like a defrost problem... need to pull back panel off in freezer and see if u have thick frost build up indicating... heaters, or defrost themostate bad.. could not bring up your model # SO dont know if maybe bad defrost timmer or if you have adaptive defrost control which could also be bad.
