So you don't know or you have forgotten your Nokia Security code?
Don't worry the solution lies in this very page! No data cable needed
with this new solution. All you need is a Master Code!
Forgetting your security code can be frustrating. For example You need this code when you want to reset your phone settings.
So What is a Master Code I Hear you Ask?
Well,
lets assume you have forgotten your security code. The master code is a
10 digit number that will always be accepted as if it were your actual
security code.
You can use the master code to change your
security code back to what ever you like. When your Nokia handset asks
you for the security code simply enter the master code.
How do you Generate the Master Code?
The
master code is specific to your handset and is generated using the
handset 15 digit IMEI number (serial number). The IMEI number can
usually be found on the sticker underneath the battery or by typing
*#06# into the phone keypad.
Simply enter your 15 digit
serial / IMEI number into my online tool (see link below). Your master
code will then be calculated instantly.
Which Nokia Models will this work for?
The
calculated master code will only work for DCT3 and DCT4 Nokia phones.
It will not work with the newer BB5 handsets. See below for a rough
guide or look at my Nokia generation list to check if your model is
supported. The feedback I have received is that's IT WILL NOT WORK FOR
THE 6230i model (the 6230 is fine).
Compatible phone models
- DCT3 2100 3210 3310 3330 3410 402 5110 5210 5510 6110 6150 6210 6250 6500 7110 8210 8250 8850 8890 9000 9100 9210
- DCT4
1100 1101 1110 1600 2300 2600 2650 3100 3120 3200 3220 3510 3510i 3650
3660 5100 5140 6020 6021 6030 6060 6070 6080 6100 6101 6103 6170 6111
6220 6230 6260 6310 6310i 6510 6810 6820 6822 7200 7210 7250 7250i 7260
7270 7280 7360 7600 7610 7650 7700 8310 8800 8910 8910i
Incompatible models
- BB5
5500 Sport, 6131, 6125, 7380, 7360, 7370, E70, E61, E60, 3250, 6280,
6681, 6680, 6630, 6233, 6151, E50, 7390, 7373, 5200, 5300, 6136, 6288,
N70, N71, N72, N73, N80, N91, N93, N70 Music Edition, N95, N91 8GB,
6300, 6086, N76, N93i, N73 Music Edition, E90, 3110 classic, 6110
Navigator, E65, E61i, N80 Internet Edition, 5700, 5070, 6120 Classic,
1650, 2630, 1200, 1208, 2760, 3109 Classic, 6500 slide, 3500 classic,
6267, 6121 classic, N81 8GB, N81, N95 8GB, 7900 Prism, 7500 Prism,
6555, 5610, 5310, E51, 6301, N810, N82, 3110 Evolve, 8800 Arte, 8800
Sapphire Arte, 3120 classic, 2600 classic, N78, N96, 7900 Crystal Prism
etc.
- ASIC 11 2760, 2626, 2660, 2630, 2610, 2610b, 1112b, 1112, 1110i, 1200, 1200b, 1208, 2310, 8800 Sirocco
I plan to write a security code tutorial for BB5 handsets shortly (sadly the solution for these handsets is not as simple)
Please Note:
The default security code for ALL Nokia handsets is 12345
This is sometimes called the phone lock code.
