SOURCE: GE Side by Side, water leak inside freezer door
you will need to [possibly replace the solinoid valves on the backdside of the refrigerator
Right hand side wall in the freezer - take a look- any frozen water or moisture? Need check a drain line, usually defrost heater inside the freezer wall getting bad and draining water just freezing inside of it.
SOURCE: fridge is leaking from freezer to top shelf
This is the drain tube that runs in the back of the freezer on the bottom is pluged. Take a sprayer with some hot water in it and flush out the system. Remove the food so that you dont get any of the stuff on it.
SOURCE: Leaking water inside fridge/freezes the food
Most likely your defrost condensate drain in the rear of your freeze is frozen over. I have put together a long page on the link below. Little too much about leaks in refrigerators and how to solve the problem to fit this page. Choose the part that applies most to your situation and let me know how I may help you resolve yours. I'll be here if you need so click on the link below, Thanks, Sea Breeze
HOW TO FIX A DRAIN LEAK INSIDE REFRIGERATOR AND FREEZER PART 2
SOURCE: Freezer compartment leaking water and icing up inside
I just fixed this problem with my Admiral. I noticed the problem when I found ice in the bottom of the freezer and water leaking out onto the floor. Here is what I did: remove all of the food from the freezer into large coolers. Pull-out the shelves, the icemaker bin, and thaw the basket with a hairdryer until you can pull it out. There are about 12 phillips head screws that hold a plastic baffle covering the freezer coils. Remove all of the screws and loosen but do not remove the icedispenser motor and freezer light (you can pry it up to get to the top screw of the baffle). Pull the top part of the baffle away from the back of the freezer and then slide the baffle up to reveal the defrost drip tray and drain. Use a hair dryer and screw driver to remove the iceblock from the drip try and to thaw any other ice in the bottom of the freezer. Also thaw the top of the drain. Now pull the freezer out from the wall and under the drain area in the back you will find the drain tube attached with a "Oh-Jesus" clamp - at least that is what we call them here in Indiana. Pinch the clamp with pliers and pull the drain tube down. Use a stretched out wire hanger to snake out the tube (I had lots of calcium deposit and a dust ball clogging the tube) and then replace. Test the system with a cup of water to make sure the drain works (should see water end up in the pan under the right front bottom drip tray). Replace baffle, icemaker motor/light, bin, shelves, food, done.
Thank you for your post, friend!
Based off the information you have provided your Frigidaire refrigerator is leaking water inside the fresh food compartment. If you could provide me your model number I would be able to provide more information. You can normally locate your serial tag (which lists your model number) on the inside cabinet of the fresh food compartment normally on the left side of a top mount. On a side by side it can be found on the right hand side. I look forward to your response. -Matt
