Contact your service provider and get the network unlock code for your Alcatel OT-606 from them, if they don't give you the code, you can still get it from online sites.Try Onlinegsmunlock.com , they provide codes at affordable price with simple unlocking instructions!!
A bench grinder has left handed threads on one shaft and right handed on the other,so that the grinding stones don't unscrew the nut as you grind something.I haven't ever gotten around to getting a bench grinder,but on my father's, I used to just hand tighten the nut,then grab the grinding wheel with my hand while tightening the nut with a wrench.(You don't have to make it real tight,as the wheel pushing against the nut will keep it tight)
Don't worry i will help you to fix this problem,If your mobile Phone says contact service means you need to unlock it.It locked to network,You can get the Network Unlock code from the site for Nokia 2610 at here Unlocking4u.com and unlock it then you can use with any GSM Network Sim card.
Contact service problem to any cellphone is due to EEPROM...need to reprogram it to fix the problem. If you don't know how to reprogram...just go to the nearest repair center to fix the problem
If your mobile phone displays Phone Restricted with an Undo option and selecting Undo results in an Enter Restriction Code error, your mobile phone is Network Locked. This means your mobile phone has been restricted for use on one specific network and a Restriction Code or Unlock Code must be entered before the phone can be used with alternative networks.You can get the Restriction Code at here Onlinegsmunlock and Unlock it from Network Lock,Then Nokia Mobile Mostly asks for restriction code!Your Phone Brand,model,Network,Country it locked you need to specify it...
Check the connection on starter motor witch is down close to engine and looks like cylinder and have 2 big nuts and 2 small.If not ask someone to put the key in contact and you check the voltage on that to big nuts ( some starter motors have only one big nuts the ground is directly to the body ).If you have 12 volt on your starter, that means the motor is ( ca-put ) broken. If you don't have 12 volt must check the line between starter and relay on the board. Could be possible to have dry joints on reley contacts, and must be changed ( the reley ).
It is possible that the Linksys wireless doesn't have any password/WEP key to connect that is why your phone can connect to it. You can't the other networks available if you don't have the password/WEP key. It has password enabled to prevent unauthorize connection to the wireless. I suggest you subscribe to your own wireless connection so you don't need to worry about connecting to any wireless network available.
Hi, the PUK code of the Sim card will be provided by the Network Carrier of the Cellphone. Please contact the Customer Care of the Network Carrier to get the OUK Code. If you don't know the number of your cellphone you can tell the number present in the SIM card to get the PUK Code. Whatever the condition, I suggest that you contact the Customer Care to get the PUK Code.
Sir if their is any problem with the network then put your Sim card in another mobile.Then you can know that you are not getting the network because of your mobile or not.If still the problem remains then please contact with your network provider.They will take necessary action against that.Don"t worry.
