This should be your iphone lcd screen caused by the failure, it is recommended to detect. If you need to change, you can go to this site to seek help. Apple iPhone 4S LCD Screen and Digitizer Assembly with Frame Black
Chances are your LCD is bad. If You still are not sure about what is wrong then you can order diagnostics service to. Go To http://www.iPhoneReplacementParts.com To Get Your Parts Today.
Your problem sounds to me like possibly and LCD problem. The iPhone is so delicate that the lcd and digitizer will stop working with one drop.
If you have dropped your phone before chances are the lcd got damaged. it can be replaced relatively inexpensive.
So Hook it up to itunes and see if it mounts, if it does, chances are your lcd is bad.
If a hard reset doesn't cure it and there is no bootup sounds at all, you have a broken logic board. There is an iphone repair website that shows you how to do the replacement yourself and a third party iphone repair company that can do it for you.
Have a look at www.modmyi.com. You are probably in DFU mode.
Take it to an apple store.
