Passport 8500 Radar Detector Logo
L
Larry Adams Posted on Sep 22, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a dodge pickup 5.7 liter engine and I put a escort 8500 in it and whenever I accelerate it goes off
My truck is a 2011 dodge 2500
Steve
Level 3:
  • Master 3,290 Answers
  • Posted on Sep 22, 2015
Steve
Master
Level 3:
Answers
3290
Questions
Helped
1127308
Points
12184
"Goes off" as in shuts off or provides an audible / visual radar alert?
Are you connected to the cigar lighter / battery; or a wire you believe to be 13.8VDC? Check the voltage of the wire you are using to power the 8500 with a VOLTMETER. You may be connecting the data bus wire in the vehicle instead of a 13.8VDC source. Move the wire to a 13.8VDC source.
What should the fuel pressure be from the fuel pump on my 1988 Dodge Ram 50, 5 speed, 2 liter, 4 cylinder engine be?]
Seems like an accelerator pump is worn out in the carb.To check it take off air cleaner and pump the throttle body by hand and see if it squirts in the top of the carb with engine off.Or bad fuel filter.
2answers
1997 dodge ram 1500 4x4 abs light on runs fine idles good but put it into gear wont go past 35 mph engine running smooth even at 35 mph
Bernard's Blog: Dodge Transmission Output Speed Sensor
bernardsblog.blogspot.com/.../dodge-transmission-output-speed-sensor.h...
Sep 8, 2009 - My 99 Dodge 2500 Ram won't accelerate..transmission is NOT slipping,.... It has been running fine and the check engine light even cleared itself yesterday.... So it wouldn't go into first gear and then 3 minutes later my check engine ... I have a1997 Dodge Ram 1500 with a 5.9L instead of the stock 5.2L. It ...
Dodge Ram Idle and Stalling Problems - Car Forums at Edmunds.com
forums.edmunds.com > Dodge > Dodge Ram Pickup 1500
Aug 17, 2011 - 30 posts - ‎25 authors
Learn more about Dodge Ram Pickup 1500 at the Edmunds.com ... The crank sensorwas put on however it started stalling again. ... The truck starts fine, but will only runat 2000's RPM and only then if .... Then as I start driving about 1/3 of a mile go dead again, I knockout of gear, crank back up immediately.
WILL NOT GO OVER 30MPH WITH PEDLE TO METAL ...
repairpal.com > Questions > Dodge > Charger > 2006 Dodge Charger
I WAS DRIVING FINE AND THE CAR ACTED LIKE IT GOT STUCK IN ... Then the transmission didn't want to change into 2nd gear. .... Whenever i start up my car theabs and esp light turn on and when i try driving it doesnt go over 30 mph even .... in neutral but not it just wont go up hills and i think it has something to do with
Fireing digram of 1999 dodge ram cummimgs 24 valve 5.9 diesel
Check this firing order for each engine...
1999 Dodge RAM 2500 ¾-Ton Pickup 5.9 liter V-8 VIN "5" HDC
1999 Dodge RAM 2500 ¾-Ton Pickup 5.9 liter V-8 VIN "Z" LDC
Hope this helps (rememnber to rating this free answer).
2helpful
2answers
My daughter has a 95 Ford Escort Wagon. The temperature gauge either does not work at all or it bounces back and forth with acceleration or deceleration. The gauge goes up when you accelerate and it goes...
connector may be loose at the temperature sensor. connector should be snug on the sensor. If necessary, bend the terminals carefully to make firm contact. If this does not solve the problem, you may want to replace the sensor. Please let me know if you have questions, and thanks for using FixYa.
1.8 liter engine:
jturcotte_1544.gif 1.9 liter engine:
Firing order diagram for 96 dodge ramp 1500 van v6 3.8 engine
Note this information, about Dodge RAM 1500 have 3.9 engine... 1996 Dodge 1500 Pickup 3.9 liter V-6 VIN "X"
This is for one 3.8L V6 1996 Dodge 3.8 liter V-6 VIN "L"
Hope helps (remember rated this).
4helpful
Fireing order for dodge ram pickup
Here is a firing order diagram for that vehicle with a 5.2 liter or a 5.9 liter V-8 engine. If it has a 3.9 liter V-6 engine then let me know and I also have that firing order diagram if you require it.
Firing order for 3.9 ram charger
The Ramcharger only lists a 5.2 or a 5.9 liter engine for that year, but the D-100 pickup showed a 3.9 liter engine. Here are the the diagrams for all of those engines, and the 5.2 and the 5.9 liter have the same firing orders.
3.9 liter engine.
5.2 liter and 5.9 liter engines.
Heat only comes out hot when accelerating, this van has a 3.3 liter engine. I also have this same problem on my 1994 Dodge Dakota pickup truck with a magnum v-6 engine... whats going on ???
check the coolant level in both vehicles, low coolant is the primary cause of this problem, check at the radiator not in the expansion tank, might be air bound,check and get back to me. Please rate my fix as i strive to be the best. Thanks Ray
Top Escort Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
john h
Are you an Escort Vehicle Part and Accessory Expert? Answer questions, earn points and help others
