Question about Singer 9960 - 9960 Quantum Stylist
How do I correct excessive noise and rattling of bobbin in Singer Quantum Stylist 9960 model sewing machine?
I have tried many things--it is threaded correctly, no parts are missing, tensions are correct, same thread type in bobbin and upper, using teflon bobbin washer in bobbin case, bobbin case cover intact and in place. It makes a terrible racket.
Do NOT oil!!
You need to have the bobbin case replaced. I had mine replaced under warranty.
Posted on Dec 24, 2019
2 Suggested Answers
Anonymous
SOURCE:
acyron
  • 61 Answers
SOURCE: my singer quantum stylist 9960 bobbin case squeaks while sewing the stitches are fine its just sounds terrible
Oil it! Put a drop of oil on everything hat moves every eight hours of operation," except plastic gears etc". Use only Singer oil on Singer machines. Plastic gears require a grease made from plant.. "Do not use petroleum based oils or grease on your machine,it will dissolve the plastic gears etc". used in your machine..
Posted on Nov 13, 2013
Testimonial: "but the manual says do not oil this machine"
Troubles with the bobbin tension on the singer quantum 9960
the small flat spring on the bobbin holder under which you pull the thread is the tension setting for bobbin thread
it extremely delicate and just a partial turn of the screw that holds that spring in place has a large influence on the tension
mostly problems here are that the needle tension is insufficient and causes the problems
Oct 02, 2016 | Singer 9960 - 9960 Quantum Stylist
My sewing machine jammed, not it won't turn on and reset
Mine is doing the same thing. Have you found what the problem is? My email is laneytay@msn.com
May 18, 2014 | Singer 9960 - 9960 Quantum Stylist
Bobbin bunches up
Classic burr on the hook problem would be my first guess. If the thread remains on the hook when it makes the next revolution all sorts of ugly things happen such as you described. I made a video that might help.
Nov 17, 2013 | Singer 9960 - 9960 Quantum Stylist
My singer quantum stylist 9960 bobbin case squeaks while sewing the stitches are fine its just sounds terrible
Nov 13, 2013 | Singer 9960 - 9960 Quantum Stylist
Singer 9960 automatic thread cutter not working
I'm looking for a solution to why the thread cutter isn't working. It just pulls the thread into a knot and jams the bobbin case. I was hoping for an answer here but the answer had nothing to do with the question!
Sep 20, 2013 | Singer 9960 - 9960 Quantum Stylist
Singer 9960 - 9960 Quantum Stylist Logo
335 people viewed this question
Top Singer Irons Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Are you a Singer Iron Expert? Answer questions, earn points and help others
