Removal
Raise the rear of the vehicle and support if securely on jackstands after loosening the lug bolts of the left rear wheel. Take off the wheel.
Find the clutch release lever on the upper left side of the transaxle and unhook the cable from the lever.
Remove the pedal cluster and unhook the clutch cable from the clutch shaft.
Pull the clutch cable forward, through the center tunnel, and out the hole for the pedal cluster.
Installation
Coat the new cable with multi-purpose grease.
Find the front end of the cable guide tube by reaching into the hole for the brake and clutch pedal cluster. Grasp the tube with your fingers and insert the new cable into the tube.
After you ve started the cable into the tube, push it to the rear, through the tube. If you need to, lubricate the cable with multi-purpose grease as you push it into the tube.
The "sag", or bend, in the clutch cable guide tube is important - the friction it imposes on the cable minimizes clutch chatter. To alter the sag, install or remove washers between the holding bracket and the end of the cable tube.
Now adjust the clutch pedal freeplay.
