Press "end of cycle" to get machine to normal. Then plug off the wall. Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
SOURCE: Washer frequently stops cycling at 14 and 27 minutes remaining
I have the same exact problem... can't believe it's just me. I too would love to know what's wrong with this machine! Is their a recall for this???
SOURCE: E:27 error code. Wet
E:27 message means that the door locking mechanism has malfunctioned and/or is overheating. Unplug the machine for 30 minutes and try again. If that doesn't solve the problem you need to call the service.
