My mum scanned a document now when she copies anything smaller than that document the scanned document is also copied in the background.
How do we get rid of the scanned document?
No wi-fi is set up for this printer.
The lcd screen says sort copy:01 i have tried stack copy.
I have tried scanning another document but doesn't allow error
Copying documents is fine. Printing is fine.
Tried resetting & on/off.
Yep, only when you use the document feeder? If so, lift the document feeder lid, get a clean lint-free cloth and some glass cleaner. Apply some of the cleaner to the cloth then, clean the small of the two glass areas. That is the only section that reads documents fed through the document feeder! Run a blank sheet of paper through the document feeder first before cleaning and make a copy. Take the copy and, if there is a line (or lines)on the copy, place it on the larger document glass face up.Follow the line to the smaller glass. The dot of debris will usually be there. If you don't see anything wrong, clean the glass anyway. Run another blank sheet through the document feeder. Check that copy. If the lines are gone...Viola! you have solved the problem. It it has not and you've cleaned it more than once, the debris is on the mirrors under the glass and a technician will need to come out, remove the glass and carefully clean the optics/mirrors.
Good Luck.
If this only occurs when using the document feeder then you will need to clean the smaller glass that sits next to the large glass that you manualy place your documents. The document feeder scans the originals over the small glass and any ink ,whiteout that may be on the glass will appear as lines down the pages
Happened with me too. Turned out to be a small sticky smudge on the ADF glass. That is the smaller glass scan area to the left of the large glass scanning area. When using the ADF to scan or copy, make sure the smaller glass area is clean along with the rollers.
You might be scanning and copying in full color even for regular documents. When you do this, it treats the document as a photograph or color document and therefore, the background, even if white, is scanned in as a bit yellow
Lift the lid and to the left of the main glass is a smaller glass; that is what scans during the feeding process. Make sure that it is completely clean; even a speck of dust can cause a line to appear. I took a lens wipe and cleaned mine and my line was gone.
Take it into photoshop cs3.Type the text over the scanned text that u want to erase.resize the typed text to match the scanned one.
2)make a layer copy of the background layer.Turn off the original background layer.then, create a layer mask for the copied layer.and paint black over the area u want to erase, with the layer mask active.
If u don't no photoshop OR in case, u couldn't figureout what i said,then mail me ur scanned image and the text file to [email protected]. i ll fix it and mail u back the edited copy.THANK YOU!!!
