Measure with tape measure. Or if buying ask seller to get tape measure. Or if buy new one to replace model gone for disposal, measure the space available.
All fairly standard size anyway unless 'compact' model.
The dimensions of the Kenmore refrigerator model 106 are known according to their height without hinges as 65 ? in. and with the hinge as 66 ¾. In addition, they are 32 ? in-depth without handles and 33 ? in-depth with handles. https://homeguideinfo.com/kenmore-refrigerator-model-106-dimensions/
You would be safe if you used the current dimensions for todays
18cf Top freezer ref. 28" w x 67.5" h x 31" d
You are right no published spec's left too old I guess?
May I suggest measuring the space allowed for the fridge?
Hello pamnwillie, To perform a "System Restore. " Follow these instructions carefully, and you will have no problem at all. The first thing you want to do is click on the "Start Button," from the Desktop. Next, click on "All Programs," scroll to find "Accessories," next select the "System Tools. " You will see in the next window that open, "System Restore! "Now this is very important! Once you click on the System Restore "shortcut" it will start to look for the last known time of a change in your computer. The System restore can take as long as a 1/2 an hour to run, so be patient "Do not try to do any type of work, don't even touch the keyboard for any reason, just let it run!" Once the System Restore finds the correct "Date and Time"of the event; choose the Date closest to the time of the occurrence. .
Now once again, there will be a message telling you not to do anything with the computer, and please don't. The System Restore will "run" for a while, so once again be patient.
The computer will then "Shutdown and Restart." Lo-gin if you have to; but! Do not touch the Keyboard once the Desktop window open, because System Restore is still running. Wait! Until there is a message letting you know the Restore of your System was successful! Take your time. "I hope all goes well, please let me know if you need further assistant. Best Regards. Thanks for using Fix'Ya."
There are 4 different versions sound card drivers for this Dell Dimension model (4600).
Go to 4600 and select Audio then download which version from the list for your desktop.
