Whirlpool Duet GHW9150P Front Load Washer Logo
Posted on Jul 12, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Clothes do not get clean. Washer twist clothes in knots Washer stinks smells musty like maybe water is not draining properly
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 24, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
3335
Points
My pant legs and long sleve shirts twist into a knot, every time. How can I stop this from happening?
  • 1 more comment
  • peggy schrabeck
    peggy schrabeck Feb 18, 2014
    I am sick of this happening and there is no solution
  • peggy schrabeck
    I will never buy another front load washer, it does not clean well and there is not enough water in the wash cycles and no way to add more
  • Ginger Gams
    Ginger Gams Dec 28, 2018
    Same here everything g twisted
Chris Huff
Level 3:
Top Expert:
  • Whirlpool Master 6,289 Answers
  • Posted on Dec 28, 2018
Chris Huff
Whirlpool Master
Level 3:
Top Expert:
Answers
6289
Questions
Helped
2017781
Points
74913
Most likely bad transmission
2answers
Clothes come out musty
I would put in some bleach and clothes that can handle it without damage and run a wash cycle. Leave the door open when you are done using the machine, or at least un-latched. There are commercial products, but bleach will do the same thing. You have stuff growing on the gizzards inside the drum, and bleach will likely kill them. They like dark & humid places.. guess what... that's your washer with the door kept latched.
How do we clean with this machine .
Is this a front-load washer or top load?
Is the machine operating properly, or are your clothes getting a musty smell?
The musty smell has a few solutions, One may work but probably a combination of all will work best.
Immediately move wet clothes to the dryer, do not let them sit in the washer for a long time.
If your clothes smell, put mouthwash with your clothes directly in the tub during the wash cycle (this will not stain your clothes)
leave the door open when not in use (lets it dry out)
If the washer smells, use bleach and hot water in an empty cycle once in a while (kills just about every kind of bacteria or mold which may be causing the smell)
Use washing machine cleaner once in a while(can be found at your local grocery store isle next to detergent)
Dry your clothes completely, damp clothes can start to smell again.
If you are looking for a new washer, try to find a newer model that features a stainless steel tub with silver impregnation. The silver is a natural disinfectant.
4helpful
Clothes stink
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hope your filter is clean. Don’t wait for the machine to jam to look into your filter.
You can use Affresh to clean your front loader. Deposits of soap and other such things can be stuck around the inside tub of your washer. Try this product, it works great on all front loaders. Use very hot water with the Affresh pellet with no clothes and run the machine through a cycle. Also helps with any stagnant water smells. Put the Affresh pellet inside the machine, not in the soap dispenser.
You can give me a ‘very helpful’ rating for the free help, can't you. Thanks.
My clothes are coming out smeeling musty
I have a zwf1241w with similar problem. When I disconnected the drain hose that runs from the drum casing to the pump housing there was a lot of collected debris that had prevented the water from draining through properly. You could try clearing this out.
4helpful
5answers
MY FRONT LOAD WASHER STINKS! THERE IS A MUSTY ODOR COMING FROM INSIDE.
I have the same problem with my machine. Also a frigidaire. After speaking with many repair people apparantly this is a common issue. With mine the gasket that seals around the door has separated completely from the machine and you can literally lift is away. If you pull it back you can run your finger along the metal of the machine and lift of soft black mold. I am in the midst of trying to get my machine replaced with another brand under warranty. This has actually caused severe allergic reactions to my family and took over 6 months to find.
2helpful
2answers
1994 Kenmore 90 series washer smells musty
Do a boil wash without clothes & detergents, with a cup of bicarbonate of soda in the soap drawer.
2helpful
3answers
Laundry stinks
I find that the dryer does not dry the clothes enough. The washer can take a lot of laundry at one time but the dryer is not able to handle the load. The stink usually comes from a bit of moisture left in the the clothes, especially the towels. Break down your dryer loads or dry them on a timed cycle for a longer time.
2answers
Our Clothes smell musty and the washer smells too
clogged water screens , defective water level pressure switch , clogged drain, kinked drain hose ,. defective water pump , defective water tempeerture switch, damaged water valve solenoid , water inlet valve has an interal malfunction
4answers
Stinky clothes
I have the same problem - the clothes smell like they have been left in there for a week - stale or moldy.
It only happens with dark clothes - I have started adding color safe bleach or oxy clean and sometimes a tiny spash of bleach - it seems to have solved it.
1helpful
Clothes smell musty
The big door seal is probably the problem. Put on gloves and using a solution of Laundry detregent and hot water and rags, carefully wipe clean all the folds of the seal. It will be icky. Next run a cycle with some detergent and oxyclean or bleach if you have it.
Especially during warm weather, damp clothing left in a front loader mildew slightly very quickly- you can't really see much but you can smell it! So get the clothes in to the dryer immediately. You'll want to relaunder the smelly clothing after you have cleaned the washer.
Good luck to you and Thank You using FiX YA!
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
